stimulated by the discussions with
The idea is that the differential and common modes comes from a matrix diagonalization.
The contents of the article are not particularly new nor exciting. They might however give another point of view and I have to say that I have not yet seen a textbook presenting this mathematical point of view on the differential pair.
Here is the article:
http://www.electroyou.it/darwinne/wiki/ ... e-symmetry
I am not very good at doing calculations, so if someone can check the results...
Also, if you spot some typos or some grammar errors/horrors, I would be extremely happy to correct them, so we might discuss here. I am in general eager to learn from my errors, about the language, the algebra or the electronics. Can someone check the bibliography? For example, I am on vacations right now and I do not have the Sedra/Smith book here.
Finally, if you judge interesting the article I wrote in English, I would like to prepare a translation a day or another. Of course, if someone would like to translate it in Italian, I would be very happy for that and we can collaborate!
and
would contain only first-order terms in
etc.
for an output voltage in an English text
(lower-case letter with upper-case subscript) is the total base voltage,
(upper-case letter with upper-case subscript) is the DC component of
(lower-case letter with lower-case subscript) is the signal. The symbol
can then be used for the Fourier transform of
instead of
(Anonimo).
ain't
, right?
in lieu of
for
arithm.
