FidoCadJ 0.24.1 beta ed ottimizzazione sotto MacOSX
Paolino,
fairyvilje
45 messaggi
• Pagina 3 di 5 • 1, 2, 3, 4, 5
Grazie a tutti quelli che stanno fornendo i loro tempi. Qualcuno può vedere come funziona con Windows?
DarwinNE
31,0k 7 11 13 - G.Master EY
La prima prova è stata fatta senza aggiungere alcuna opzione al comando java -jar fidocad-eccetera.
Usando
ottengo
Usando
ottengo
Dando
Spero serva a qualcosa :)
Puoi fare delle prove seguendo le indicazioni che ho dato a spud
Usando
- Codice: Seleziona tutto
java -Dsun.java2d.opengl=True -jar fidocadj06212012.jar
ottengo
MP: Time elapsed: 12.0; record: 7.0 ms
MR: Time elapsed: 11.0; record: 3.0 ms
R: Time elapsed: 1270.0 averaging 1461.27ms in 100.0 redraws; record: 1238.0 ms
MP: Time elapsed: 14.0; record: 7.0 ms
MR: Time elapsed: 13.0; record: 3.0 ms
R: Time elapsed: 1384.0 averaging 1460.5049504950496ms in 101.0 redraws; record: 1238.0 ms
MP: Time elapsed: 11.0; record: 7.0 ms
MR: Time elapsed: 3.0; record: 3.0 ms
R: Time elapsed: 1598.0 averaging 1461.8529411764705ms in 102.0 redraws; record: 1238.0 ms
MP: Time elapsed: 19.0; record: 7.0 ms
MR: Time elapsed: 10.0; record: 3.0 ms
R: Time elapsed: 1487.0 averaging 1462.0970873786407ms in 103.0 redraws; record: 1238.0 ms
Usando
java -Dsun.java2d.opengl=false -jar fidocadj06212012.jar
ottengo
MP: Time elapsed: 14.0; record: 9.0 ms
MR: Time elapsed: 13.0; record: 0.0 ms
R: Time elapsed: 347.0 averaging 168.91150442477877ms in 226.0 redraws; record: 8.0 ms
MP: Time elapsed: 12.0; record: 9.0 ms
MR: Time elapsed: 9.0; record: 0.0 ms
R: Time elapsed: 330.0 averaging 169.62114537444933ms in 227.0 redraws; record: 8.0 ms
MP: Time elapsed: 9.0; record: 9.0 ms
MR: Time elapsed: 14.0; record: 0.0 ms
R: Time elapsed: 331.0 averaging 170.32894736842104ms in 228.0 redraws; record: 8.0 ms
MP: Time elapsed: 13.0; record: 9.0 ms
R: Time elapsed: 337.0 averaging 171.05676855895197ms in 229.0 redraws; record: 8.0 ms
R: Time elapsed: 339.0 averaging 171.78695652173914ms in 230.0 redraws; record: 8.0 ms
Dando
java -Dsun.java2d.trace=count -jar fidocadj06212012.jar
R: Time elapsed: 325.0 averaging 166.18965517241378ms in 58.0 redraws; record: 9.0 ms
R: Time elapsed: 30.0 averaging 163.88135593220338ms in 59.0 redraws; record: 9.0 ms
R: Time elapsed: 347.0 averaging 166.93333333333334ms in 60.0 redraws; record: 9.0 ms
30 calls to sun.java2d.loops.MaskFill::DrawAAPgram(AnyColor, Src, IntRgb)
791 calls to sun.java2d.loops.DrawGlyphListAA::DrawGlyphListAA(AnyColor, SrcNoEa, IntRgb)
1492 calls to sun.java2d.loops.MaskBlit$General::MaskBlit(IntBgr, SrcNoEa, IntRgb)
40 calls to sun.java2d.loops.Blit::Blit(ByteIndexedBm, SrcOverNoEa, IntRgb)
6 calls to sun.java2d.loops.FillSpans::FillSpans(AnyColor, SrcNoEa, AnyInt)
1 call to sun.java2d.loops.MaskBlit::MaskBlit(IntArgb, SrcOver, IntArgb)
5986 calls to sun.java2d.loops.Blit::Blit(IntRgb, SrcNoEa, IntRgb)
2233 calls to sun.java2d.loops.DrawLine::DrawLine(AnyColor, SrcNoEa, AnyInt)
80 calls to sun.java2d.loops.MaskFill::FillAAPgram(AnyColor, Src, IntRgb)
1 call to sun.java2d.loops.Blit$GeneralMaskBlit::Blit(IntArgb, SrcOverNoEa, IntArgb)
368 calls to sun.java2d.loops.DrawRect::DrawRect(AnyColor, SrcNoEa, AnyInt)
12348 calls to sun.java2d.loops.Blit::Blit(IntBgr, SrcNoEa, IntRgb)
433646 calls to sun.java2d.loops.MaskFill::MaskFill(AnyColor, Src, IntRgb)
1 call to X11CopyArea
1492 calls to sun.java2d.loops.MaskBlit::MaskBlit(IntArgb, AnyAlpha, IntRgb)
1492 calls to sun.java2d.loops.Blit::Blit(IntBgr, SrcNoEa, IntArgb)
79 calls to sun.java2d.loops.Blit$GeneralMaskBlit::Blit(IntArgb, SrcOverNoEa, IntRgb)
769 calls to sun.java2d.loops.FillRect::FillRect(AnyColor, SrcNoEa, AnyInt)
1 call to X11DrawRect
3 calls to sun.java2d.loops.DrawPath::DrawPath(AnyColor, SrcNoEa, AnyInt)
79 calls to sun.java2d.loops.MaskBlit::MaskBlit(IntArgb, SrcOver, IntRgb)
6 calls to sun.java2d.loops.FillPath::FillPath(AnyColor, SrcNoEa, AnyInt)
18 calls to sun.java2d.loops.DrawGlyphList::DrawGlyphList(AnyColor, SrcNoEa, AnyInt)
460962 total calls to 23 different primitives
DarwinNE ha scritto:Nico89, hai attivato l'opzione apple.awt.graphics.UseQuartz oppure no, per ottenere i 27 ms per il ridisegno? E per ottenere i 36 ms?
Ho seguito le istruzioni del primo post
Allora, riassumo:
Per quanto riguarda MacOSX, fino ad adesso l'opzione apple.awt.graphics.UseQuartz va attivata sempre, perché i tempi sono molto migliori.
Per quanto riguarda Linux, sun.java2d.opengl può funzionare riducendo i tempi, non avere nessun effetto, oppure anche avere un effetto parecchio deleterio...
Qualcuno può darmi qualche tempistica sotto Windows (senza attivare nessuna opzione)? Attenzione perché se seguite attentamente le istruzioni, vedete che consiglio di attivare il profiler solo dopo aver caricato il file di prova, altrimenti la misura del tempo minimo risulta falsata.
DarwinNE
Questa è la mia prova su Windows 7 (64 bit), processore AMD Phenom 3.20GHz quadcore e 4GB di ram.
i tempi:
java version "1.7.0_05"
Java(TM) SE Runtime Environment (build 1.7.0_05-b05)
Java HotSpot(TM) Client VM (build 23.1-b03, mixed mode, sharing)
i tempi:
R: Time elapsed: 328.0 averaging 328.0ms in 1.0 redraws; record: 328.0 ms
MP: Time elapsed: 47.0; record: 47.0 ms
MR: Time elapsed: 0.0; record: 0.0 ms
R: Time elapsed: 281.0 averaging 304.5ms in 2.0 redraws; record: 281.0 ms
MR: Time elapsed: 16.0; record: 0.0 ms
R: Time elapsed: 250.0 averaging 286.3333333333333ms in 3.0 redraws; record: 250.0 ms
MP: Time elapsed: 0.0; record: 0.0 ms
R: Time elapsed: 312.0 averaging 292.75ms in 4.0 redraws; record: 250.0 ms
MP: Time elapsed: 47.0; record: 0.0 ms
R: Time elapsed: 265.0 averaging 287.2ms in 5.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 283.5ms in 6.0 redraws; record: 250.0 ms
MP: Time elapsed: 16.0; record: 0.0 ms
R: Time elapsed: 265.0 averaging 280.85714285714283ms in 7.0 redraws; record: 250.0 ms
R: Time elapsed: 281.0 averaging 280.875ms in 8.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 279.1111111111111ms in 9.0 redraws; record: 250.0 ms
MP: Time elapsed: 15.0; record: 0.0 ms
R: Time elapsed: 296.0 averaging 280.8ms in 10.0 redraws; record: 250.0 ms
R: Time elapsed: 281.0 averaging 280.8181818181818ms in 11.0 redraws; record: 250.0 ms
R: Time elapsed: 281.0 averaging 280.8333333333333ms in 12.0 redraws; record: 250.0 ms
R: Time elapsed: 297.0 averaging 282.0769230769231ms in 13.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 280.85714285714283ms in 14.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 279.8ms in 15.0 redraws; record: 250.0 ms
R: Time elapsed: 296.0 averaging 280.8125ms in 16.0 redraws; record: 250.0 ms
R: Time elapsed: 266.0 averaging 279.94117647058823ms in 17.0 redraws; record: 250.0 ms
R: Time elapsed: 312.0 averaging 281.72222222222223ms in 18.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 280.8421052631579ms in 19.0 redraws; record: 250.0 ms
R: Time elapsed: 296.0 averaging 281.6ms in 20.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 280.8095238095238ms in 21.0 redraws; record: 250.0 ms
R: Time elapsed: 297.0 averaging 281.54545454545456ms in 22.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 280.82608695652175ms in 23.0 redraws; record: 250.0 ms
R: Time elapsed: 265.0 averaging 280.1666666666667ms in 24.0 redraws; record: 250.0 ms
R: Time elapsed: 296.0 averaging 280.8ms in 25.0 redraws; record: 250.0 ms
R: Time elapsed: 249.0 averaging 279.5769230769231ms in 26.0 redraws; record: 249.0 ms
R: Time elapsed: 327.0 averaging 281.3333333333333ms in 27.0 redraws; record: 249.0 ms
R: Time elapsed: 281.0 averaging 281.32142857142856ms in 28.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 280.7586206896552ms in 29.0 redraws; record: 249.0 ms
R: Time elapsed: 327.0 averaging 282.3ms in 30.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 281.741935483871ms in 31.0 redraws; record: 249.0 ms
R: Time elapsed: 249.0 averaging 280.71875ms in 32.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 280.24242424242425ms in 33.0 redraws; record: 249.0 ms
R: Time elapsed: 281.0 averaging 280.2647058823529ms in 34.0 redraws; record: 249.0 ms
R: Time elapsed: 266.0 averaging 279.85714285714283ms in 35.0 redraws; record: 249.0 ms
R: Time elapsed: 266.0 averaging 279.47222222222223ms in 36.0 redraws; record: 249.0 ms
R: Time elapsed: 266.0 averaging 279.1081081081081ms in 37.0 redraws; record: 249.0 ms
R: Time elapsed: 296.0 averaging 279.55263157894734ms in 38.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 279.1794871794872ms in 39.0 redraws; record: 249.0 ms
R: Time elapsed: 281.0 averaging 279.225ms in 40.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 278.8780487804878ms in 41.0 redraws; record: 249.0 ms
R: Time elapsed: 249.0 averaging 278.1666666666667ms in 42.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 277.86046511627904ms in 43.0 redraws; record: 249.0 ms
R: Time elapsed: 297.0 averaging 278.29545454545456ms in 44.0 redraws; record: 249.0 ms
R: Time elapsed: 266.0 averaging 278.02222222222224ms in 45.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 277.7391304347826ms in 46.0 redraws; record: 249.0 ms
R: Time elapsed: 312.0 averaging 278.468085106383ms in 47.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 278.1875ms in 48.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 277.9183673469388ms in 49.0 redraws; record: 249.0 ms
R: Time elapsed: 297.0 averaging 278.3ms in 50.0 redraws; record: 249.0 ms
MR: Time elapsed: 15.0; record: 0.0 ms
R: Time elapsed: 250.0 averaging 277.7450980392157ms in 51.0 redraws; record: 249.0 ms
R: Time elapsed: 281.0 averaging 277.8076923076923ms in 52.0 redraws; record: 249.0 ms
R: Time elapsed: 296.0 averaging 278.1509433962264ms in 53.0 redraws; record: 249.0 ms
R: Time elapsed: 265.0 averaging 277.9074074074074ms in 54.0 redraws; record: 249.0 ms
R: Time elapsed: 281.0 averaging 277.96363636363634ms in 55.0 redraws; record: 249.0 ms
Atlant.
Un piccolo aggiornamento.
MacOSX
Ho fatto in modo che nell'applicazione FidoCadJ.app per MacOSX la proprietà apple.awt.graphics.UseQuartz viene sempre posta a "true". Potete quindi utilizzare l'applicazione come al solito, ma è possibile che le performance siano molto migliori. Fatemi sapere cosa ne pensate (e soprattutto se ci sono problemi).
http://sourceforge.net/projects/fidocad ... g/download
Non vi stupite: questa è la versione 0.24 ed è la versione stabile, non è la 0.24.1 beta (non rilascio quasi mai pacchetti MacOSX per versioni preliminari).
Linux
Ho aperto una discussione su SF legata ai problemi di ridisegno lento riscontrati qui, ma più in generale riguardo all'installazione ed all'utilizzo di FidoCadJ con Linux:
https://sourceforge.net/projects/fidoca ... ic/5389390
MacOSX
Linux
DarwinNE
DarwinNE ha scritto:più in generale riguardo all'installazione ed all'utilizzo di FidoCadJ con Linux:
Mi permetto di segnalare nuovamente questa discussione sul forum di SourceForge. Ci sono state alcune evoluzioni, ed in particolare un utente sta cercando di preparare degli script d'installazione adatti a Linux. Io non utilizzo questo sistema operativo (anche se sono sempre su Unix) e mi piacerebbe che qualcuno desse un occhio e facesse qualche prova che integri la mia lettura del suo codice.
DarwinNE
Seguiamo le procedure del post 3 e del 21 per l'installazione e i test?
Edit: i miei tempi su windows sono normali o sono alti anche quelli?
Atlant.
spud ha scritto:Seguiamo le procedure del post 3 e del 21 per l'installazione e i test?
Lo script di installazione mi pare ragionevolmente completo. Da qui si può accedere a tutte le versioni che sono state caricate su SVN:
http://fidocadj.svn.sourceforge.net/vie ... h?view=log
Quella più recente è quella che si trova più in alto (la 362 nel momento in cui scrivo). Se ne prende visione facendo click su "as text". Non vi chiederei tanto di provarla ancora, ma più che altro di leggere il codice per vedere se è ragionevole. Dovrebbe scaricare automaticamente l'ultima versione di FidoCadJ e dei manuali ed installarli sul sistema.
Stiamo lavorando su un altro script che servirà per lanciare il programma, ma per quello c'è ancora un po' di lavoro da fare:
http://fidocadj.svn.sourceforge.net/vie ... j?view=log
Anche qui, non provatelo ancora, ma leggete il codice e ditemi cosa ne pensate. Anzi, se ve la sentite, partecipate alla discussione su Sourceforge.
spud ha scritto:Edit: i miei tempi su windows sono normali o sono alti anche quelli?
No, mi sembrano molto alti anche quelli
Proverei a giocare anche qui con l'opzione sun.java2d.opengl per vedere se cambia qualcosa, oppure sun.java2d.translaccel.
Comunque non ti preoccupare più di tanto. Il programma è un po' più lento, ma dovrebbe continuare a funzionare in maniera relativamente soddisfacente, quindi se non trovi una soluzione non ti disperare
Io stesso ho usato per un bel po' FidoCadJ in queste condizioni sul mio portatile, senza fare dei test in condizioni particolari non m'ero quasi accorto della differenza (beh, adesso il programma è più snello...).
DarwinNE
45 messaggi
