devo visualizzare su un display 16x2 una temperatura da 0 a 100 c°.
il display scrive correttamente "temp" ma la variabile no
- Codice: Seleziona tutto
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
unsigned int dato;
long volt,volt2[8];
void main(){
TRISB=0x00;
ADCON1 = 0x80;
TRISA=0xFF;
Lcd_Init();
while(1){
dato=adc_read(0);
volt= (long) ((dato*100)/634);
LongToStr(volt,volt2);
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Out(1,1,"temp=");
Lcd_Out(1,6,volt2);
Delay_ms(1000);
