Ciao a tutti,
mi sono un po' incuriosito, non essendolo, di sapere cosa facciano gli ingegneri elettronici di elettromagnetismo.
Ho trovato questo bel corso online, su YouTube.
Spero vi piaccia.
Ciao a tutti da Pietro e buona visione.
Course: ElectroMagnetic Field for EEE
Professor: Harishankar Ramachandran
Dept. Electrical Engineering
Indian Institute of Technology, Madras
Link
Lecture-1-Introduction to Vector I part
Lecture-2-Introduction to Vector II part
Lecture-3-Coulomb's Law
Lecture-4-Electric Field
Lecture-5-Electro Static Potential
Lecture-6-The Gradient
Lecture-7-Gauss's Law
Lecture-8-Poisson's Equation
Lecture-9-Energy in the Field
Lecture-10-Example Problems in Eletro Statics
Lecture-11-Fields in Materials
Lecture-12-Fields in Material Bodies
Lecture-13-Displacement Vector
Lecture-14-Capacitors
Lecture-15-Method Of Image
Lecture-16-Poisson's Equation 2Dimensions
Lecture-17-Field near Sharp Edges and Points
Lecture-18-Magnetic Field--1
Lecture-19-Magnetic Field-2
Lecture-20-Stokes Theorems
Lecture-21-The Curl
Lecture-22-Field Due to Current Loop
Lecture-23-Ampere's Law
Lecture-24-Examples of Ampere,s Law
Lecture-25-Inductance
Lecture-26-Mutual Inductance
Lecture 27 Faraday's law
Lecture-28-Magnetic Energy
Lecture-29-Magnetic Energy-1
Lecture-30-Magnetic Energy-2
Lecture-31-Generalised Ampere's Law
Lecture-32-The Wave Equation
Lecture-33-Wave Equation
Lecture-34-Poynting Theorem
Lecture-35-Skin Effect
Lecture-36-Skin Effect (Continued)
Lecture-37-Radiation&Circuits
Lecture-38-Phasor Form of Poynting Theorem
Lecture-39-Reflection at Dielectric boundaries
Lecture-40 Reflection at Dielectric boundaries (Continued)
Lecture-41-Transmission Lines
Lecture-42-Transmission Lines(Continued)-Conclusion
Elettromagnetismo per ingegneri elettronici.
27 messaggi
• Pagina 1 di 3 • 1, 2, 3
15
PietroBaima
90,7k 7 12 13 - G.Master EY
Bel colpo! Questo post, con tutto il suo elenco sarebbe da rendere permanente e facilmente accessibile iin modo da andare a riprendere i singoli argomenti (ovviamente per chi l'inglese lo ascolta e lo parla e non solo per chi, come me, lo legge soltanto - per i quali comunque i testi scritti per "sordomuti" in inglese -
-non mancano di certo!).
Piercarlo
Piercarlo
grazie davvero, c'è voluto un po' per fare tutti i copia-incolla
BTW, volevo far notare, per chi non lo sapesse, che tutti i filmati hanno anche i sottotitoli, attivabili tramite il primo pulsante in basso a destra. Spero siano fedeli.
Grazie ancora.
Pietro.
Grazie ancora.
Pietro.
PietroBaima
Mi hai fatto ricordare, i bei tempi: Il corso di “elettromagnetista” lo frequentai (per sei mesi) alla “Scuola della Motorizzazione” di Cecchignola, molto tempo fa. Bye.
StefanoSunda
2.880 3 6 10 - Master
PietroBaima ha scritto:grazie davvero, c'è voluto un po' per fare tutti i copia-incolla![]()
BTW, volevo far notare, per chi non lo sapesse, che tutti i filmati hanno anche i sottotitoli.
Grazie ancora.
Pietro.
Io ho appena copia incollato tutti i link in un documento di testo come promemoria futuro. E ora che so che ci sono pure i sottotitoli.. (ne avevo aperto uno a caso ma.... non avevo fatto caso ai sottotitoli, dopo guardo meglio).
Piercarlo
Controllato: se per sottotitoli si intendono quelle che vengono fuori dalle automatic captions di youtube sono completamente inaffidabili (in un brano il professore parlava di trovare il campo magnetico incluso nell'area di una spira percorsa da corrente e il programma lo trascriveva, più o meno, come il problema di come trovare la macchina in un parcheggio... ma si può????).
Piercarlo
Piercarlo
ahahahaha, stavo guardando, è vero...
vengono fuori dellegradissime cazz hem delle piccole inesattezze.
Diciamo che possono aiutare, ma non si può prescindere dall'audio
vengono fuori delle
PietroBaima
però il corso è ben fatto, trovo. Purtroppo non avevo controllato i sottotitoli perché mi danno fastidio, preferisco guardare la lavagna.
PietroBaima
PietroBaima ha scritto:però il corso è ben fatto, trovo..
Anch'io, nonostante i miei problemi audio con l'inglese, il corso è fatto per farsi capire e, a condizione di metterci la dovuta dose di attenzione (gli argomenti non sono una passeggiata), si riesce a seguire. Molto suggestiva anche la sigla di apertura delle lezioni... Dovrebbe essere una preghiera se non ho capito male... Una preghiera per aprire un corso di ingegneria...
Piercarlo
Piercarlo ha scritto:Dovrebbe essere una preghiera se non ho capito male... Una preghiera per aprire un corso di ingegneria...
Già, davvero curioso. Chissà se invece è solo un inno o una sigla di apertura... mah
Ho provato ad attivare i sottotitoli sulla sigla, il risultato è esilarante...
PietroBaima
27 messaggi
Visitano il forum: Nessuno e 191 ospiti
pigreco]=π
