Registro IOCA (PIC16F677)
Raccolta di codici sorgenti
[11] Re: Registro IOCA (PIC16F677)
Messaggioda Foto Utentemros » 29 ott 2013, 17:39
Codice: Seleziona tutto
       PROCESSOR       16F677
        RADIX           DEC
        INCLUDE         "P16F677.INC"
        ERRORLEVEL      -302
   __CONFIG        0x3F32
        ORG     0x00
   GOTO start
        cblock     0x20
   Count:3
   PB
   CONT
   RIPET
   CICLO
   DUTY0
   DUTY1
   DUTY2
   DUTY3
   DUTY4
   DUTY5
   DUTY6
   DUTY7
   RIPETI
   DIGIT
   ENDC
        ORG     0x04
        BTFSC   INTCON,T0IF
        GOTO    IntT0IF
        BTFSC   INTCON,INTF
        GOTO    IntINTF
End_ih
        BCF     INTCON,T0IF
        BCF     INTCON,INTF
        RETFIE
IntT0IF
      GOTO    End_ih
IntINTF
   CLRF   PORTC
   CLRF   DIGIT
D10S         ;CIRCA 10 S
        MOVLW   49
   MOVWF   Count
        MOVLW   10
   MOVWF   Count+1
        MOVLW   20
   MOVWF   Count+2
mDelayLoop1
   BTFSS   PORTA,2
   GOTO   STP
        DECFSZ  Count,1
        GOTO    mDelayLoop1
        DECFSZ  Count+1,1
        GOTO    mDelayLoop1
        DECFSZ  Count+2,1
        GOTO    mDelayLoop1
   BSF   STATUS,0
   RLF   PORTC,F
   INCF   DIGIT,F
        MOVLW   29
   MOVWF   Count
        MOVLW   10
   MOVWF   Count+1
        MOVLW   15
   MOVWF   Count+2
   GOTO   mDelayLoop1
STP
        GOTO    End_ih
start:
;   Option_REG                             *
;1)No pull-up                                  *
;2)Interrupt INT abilitato sul fronte di salita*
   BCF   STATUS,RP1
        BSF     STATUS,RP0   ; banco 1
        MOVLW   B'11000000'   ;Inte. sul fronte di salita
   MOVWF   OPTION_REG     ;No pull-up
;   Settaggio Porte *
   BCF   STATUS,RP1
   MOVLW   B'11111111'
        MOVWF   TRISB
        MOVLW   B'11111111'
        MOVWF   TRISA
        MOVLW   B'00000000'   ; C0-C7 USCITE LED
        MOVWF   TRISC
; Settaggio A/D         *
   BSF   STATUS,RP1
        BCF     STATUS,RP0   ; banco 2
   CLRF   ANSEL
   CLRF   ANSELH      ;TUTTI GLI INGRESSI SONO DIGITALI
; Resistenze di pull-Up *
;     Settaggio Interrupt      *
;1)Interrupt Abilitati      *
;2)ABILITO L'INTERRUPT INTF   *
        BCF     STATUS,RP0
        BCF     STATUS,RP1   ;banco 0
   MOVLW   B'10010000'
        MOVWF   INTCON
; INIZIALIZZAZIONE      *
        BCF     STATUS,RP0
        MOVLW   B'00000000'
        MOVWF   PORTA
        MOVLW   B'00000000'
        MOVWF   PORTB
        MOVLW   B'00000000'
        MOVWF   PORTC
;   Settaggio OSCILLATORE  *
   BCF   STATUS,RP1
        MOVLW   B'01100000'   ; IMPOSTO 4 MHz
        MOVWF   OSCCON
        BCF     STATUS,RP0
;   MAIN                             *
MainLoop
   CLRF   CICLO
   CLRF   CONT
   INCF   CONT,F
   GOTO   $-3
END
Foto Utentemros
10 1 5
[12] Re: Registro IOCA (PIC16F677)
Messaggioda Foto Utentec1b8 » 29 ott 2013, 18:23
Posso fare qualche considerazione sul codice? Ma si dai la faccio.... :mrgreen:
- L'inizializzazione del clock deve essere la prima cosa che fai non l'ultima delle inizializzazioni
- L'attivazione degli interrupt (ovvero settare il bit GIE di INTCON) deve essere l'ultima
- nella routine di interrupt non salvi il "contesto" del micro e non ti porti nella condizione necessaria la funzionamento della routine di interrupt. Questo può causare errori. Vedi "Context Saving During Interrupts" a pagina 207 del datasheet.
In particolare questo ultimo punto non è abbligatorio, ma vediamo cosa potrebbe provocare nel tuo codice.
Tu abiliti gli interrupt, scrivi tutti 0 sulle porte (A, B e C) quindi cambi banco di memoria per impostare l'oscillatore.
Hai detto prima che il pin RA2 è libero, quindi potrebbe per effetto di disturbi generare un interrupt inaspettato appena abilitato l'interrupt. Supponi che l'interrupt si verifichi subito dopo queste istruzioni:
        BCF     STATUS,RP1
Il sistema si presenta nella routine di interrupt trovandosi nel banco 1 e non 0 come ti apsetti.
Quendi la
        BTFSS   PORTA,2
        GOTO   STP
non controlla RA2 ma controllo TRISA, 2. Come conseguenza non esci mai dall'interrupt.
Ma se tu uscissi potresti, anzi lo hai fatto sicuramente, corrotto il registro W andando a caricare in OSCCON un dato diverso da quello che ti aspetti.
Anche la RLF PORTC,F non funzionerebbe a dovere con conseguenza di portare la PORTC come input e non come output e non vedere i led accendersi in progressione.
Potrebbe non accadere nulla di questo sia chiaro, ma è un bel rischio.
Fabio
Foto Utentec1b8
3.595 3 8 13
[13] Re: Registro IOCA (PIC16F677)
Messaggioda Foto Utentemros » 29 ott 2013, 22:42
Ciao Fabio
I tuoi consigli sono sempre ben accetti ! :ok:
Purtroppo manco di esperienza ed e' molto facile impazzire quando capita ciò che ha descritto nel tuo l'ottimo messaggio.
comunque ho messo il pin a massa con ma resistenza e eliminato il controllo del flag, nell'interrupt, del timer e per magia ( sedere ) e' andato tutto bene.
comunque sia seguo i tuoi consigli e modifico il firm.
Grazie e buona notte
Foto Utentemros
10 1 5
[14] Re: Registro IOCA (PIC16F677)
Messaggioda Foto Utentec1b8 » 29 ott 2013, 22:59
Ottimo :ok: =D>
Buona notte!
Fabio
Foto Utentec1b8
3.595 3 8 13
Torna a Firmware e programmazione
