![\[\begin{cases} & i_{1}=i_{C}+i_{2} \\ & V_{2}=V_{C} \\ & e= V_{1}+V_{2} \end{cases}\] \[\begin{cases} & i_{1}=i_{C}+i_{2} \\ & V_{2}=V_{C} \\ & e= V_{1}+V_{2} \end{cases}\]](/forum/latexrender/pictures/54c582dca311b6b1d8819127672944a5.png)
ora si trova...esiste un altro metodo per risolvere la prima parte?
...procediamo poi per t=0
lascerei tutto invariato tranne Vc(0)=8 che diciamo sia scontanto
poi per t>0
dovrebbe esser analogo alla prima parte il procedimento, quindi rivisito i calcoli..
![\[V_{2}=V_{C}\] \[V_{2}=V_{C}\]](/forum/latexrender/pictures/01d6cd5f4a7517047141b58fb557b807.png)
![\[V_{2}=e\frac{R_{2}}{R_{1}+R_{2}}= 8V\] \[V_{2}=e\frac{R_{2}}{R_{1}+R_{2}}= 8V\]](/forum/latexrender/pictures/d46b4747f553c7db032a61f1e3ca4e13.png)
\[y_{oV_{C}}= Ae^{-150t}\]
\[y_{PV_{C}}= Ae^{-150t}+8\] \[\begin{cases} & i_{1}=i_{C}+i_{2} \\ & V_{2}=V_{C} \\ & e= V_{1}+V_{2} \end{cases}\]
\[y_{PV_{C}}= Ae^{-150t}+8\]](/forum/latexrender/pictures/574a65a02f7aaf2a61704cc813883d83.png)
![\[R_{eq}=R_{1}//R_{2}=66.66\Omega\] \[R_{eq}=R_{1}//R_{2}=66.66\Omega\]](/forum/latexrender/pictures/8d67424048a37d02d5f37a793f2f6121.png)
![\[\tau = C R_{eq}\] \[\tau = C R_{eq}\]](/forum/latexrender/pictures/feb7dae5edaf383aaf41154ad7b2e200.png)
![\[V_{C}(0)=8\] \[V_{C}(0)=8\]](/forum/latexrender/pictures/6a1cb4ce4bc4bb26aec00ba1b545dabe.png)
![\[V_{C}= e\frac{R_{2}}{R_{1}+R_{2}}=4V\] \[V_{C}= e\frac{R_{2}}{R_{1}+R_{2}}=4V\]](/forum/latexrender/pictures/0b6153cc20fb8db6e60f02976c698148.png)
![\[y_{PV_{C}}= Ae^{-150t}+4\] \[y_{PV_{C}}= Ae^{-150t}+4\]](/forum/latexrender/pictures/9cc8571f9047d1ebd00a7a315fb4a1fd.png)
![\[V_{C}(0-)=V_{C}(0+)\] \[V_{C}(0-)=V_{C}(0+)\]](/forum/latexrender/pictures/636351d4e2f1d053f165ff866021d600.png)
![\[8=A+4\; \; \; \Rightarrow A=4\] \[8=A+4\; \; \; \Rightarrow A=4\]](/forum/latexrender/pictures/5c556cc60575991d4019baa97890c7ef.png)
![\[V_{C}(t)= 4e^{-150t}+4\] \[V_{C}(t)= 4e^{-150t}+4\]](/forum/latexrender/pictures/24a3f6de827e0ba373fbbbcb50abc70c.png)
![{{V}_{C}}(t)=[{{V}_{C}}(0)-{{V}_{C}}(\infty )]{{e}^{-\frac{t}{\tau }}}+{{V}_{C}}(\infty ) {{V}_{C}}(t)=[{{V}_{C}}(0)-{{V}_{C}}(\infty )]{{e}^{-\frac{t}{\tau }}}+{{V}_{C}}(\infty )](/forum/latexrender/pictures/cc91567c29642509e53097986335ef37.png)
![\[V_C=8V\] \[V_C=8V\]](/forum/latexrender/pictures/22048415eb3d96b73e0f5334fc66e458.png)
![\[V_C(0)=8V\] \[V_C(0)=8V\]](/forum/latexrender/pictures/1bd7cc4cbba85a59cffd26def465edbb.png)
