The A4988 stepper motor driver carrier is a breakout board for Allegro’s A4988 microstepping bipolar stepper motor driver. The driver features adjustable current limiting, overcurrent and overtemperature protection, and five different microstep resolutions (down to 1/16-step). It operates from 8 – 35 V and can deliver up to approximately 1 A per phase without a heat sink or forced air flow (it is rated for 2 A per coil with sufficient additional cooling).
1 A per fase senza dissipatore o flusso d'aria forzato, 2 A altrimenti. Qui c'è una ventola... Sarbbe interessante comunque sapere quanta corrente deve consegnare questo modulo...
