Dichiarazione per prodotti esenti da marcatura CE
L'iter relativo alla marcatura CE e problemi connessi.
Moderatore: Foto UtenteGuerra
[1] Dichiarazione per prodotti esenti da marcatura CE
Messaggioda Foto Utenteproelal » 17 ott 2008, 11:06
Lavoro per una azienda che produce e distribuisce compoenenti elettrici ed elettronici per il settore industriale.
Abbiamo da poco iniziato la distribuzione di filtri EMI per quadri elettrici, essi sono privi della marcatura CE, questo lascia perplessi i ns. clienti che ce la richiedono.
Il fornitore ci ha fornito una "guidelines" per la 2006/95/EC in cui si sostiene che i filtri sono esenti da tale marcatura, cito alcuni passaggi:
However, some types of electrical devices, designed and manufactured for being used as basic components to be incorporated into other electrical
equipment, are such that their safety to a very large extent depends on how they are integrated into the final product and the overall characteristics of the final product. These basic components include electronic and certain other components (13)
Taking into account the objectives of the ”Low Voltage” Directive, such basic components, the safety of which can only, to a very large extent, be assessed
taking into account how they are incorporated and for which a risk assessment cannot be undertaken, then they are not covered as such by the Directive. In
particular, they must not be CE marked unless covered by other Community legislation that requires CE marking.
Nota (13)
This includes, for example,, active components such as integrated circuits, transistors, diodes, rectifiers, triacs, GTO’s, IGTB’s, opto-semi-conductors; passive components such as capacitors, inductance, resistors, filters; electromechanical components such as connectors, devices for mechanical protection which are part of equipment, relays with terminals for printed circuit boards, micro switches.
Visto che il fornitore non rilascia niente, possiamo realizzare una dichiarazione in cui si attesti che il prodotto è esenta dalla marcatura?
Cosa possiamo citare nel testo?
Pensavo una cosa tipo: "I prodotti ... sono esenti da marcatura CE in basa alla Direttiva 2006/95/EC articolo... comma... "
Stefano
Foto Utenteproelal
[2] Re: Dichiarazione per prodotti esenti da marcatura CE
Messaggioda Foto UtenteUgoFonzar » 18 ott 2008, 20:56
buona idea
magari nella scheda tecnica che li accompagna
(se presente)
saluti cordiali
ing. Ugo Fonzar - Aquileia (UD)
315 1 2 6
[3] Re: Dichiarazione per prodotti esenti da marcatura CE
Messaggioda Foto Utenteproelal » 19 ott 2008, 20:12
Il problema è che non conosco l'articolo cui fare riferimento ;-)
Mi potete aiutare?
Magari citare il passo dlla Norma così sono più tranquillo?
Stefano
Foto Utenteproelal
[4] Re: Dichiarazione per prodotti esenti da marcatura CE
Messaggioda Foto UtenteUgoFonzar » 19 ott 2008, 20:38
ti riporto le linee guida in italiano sulla direttiva 73/23/CEE (la 2006/95/CE è un testo consolidato)
Rilevanza della direttiva per i componenti elettrici
9. Generalmente parlando nel campo d'applicazione della direttiva rientrano tanto il
materiale elettrico destinato ad essere incorporato in materiale d'altro genere quanto
il materiale elettrico destinato a venire impiegato direttamente.
Alcuni tipi di dispositivi elettrici, progettati e fabbricati per venire impiegati come
componenti di base da incorporare in altro materiale elettrico, sono tuttavia tali che
la loro sicurezza dipende in misura molto larga dal modo in cui sono integrati nel
prodotto finale e dalle caratteristiche globali di quest'ultimo. Nel novero di questi
componenti di base rientrano i componenti elettronici e determinati componenti
d'altro tipo11.
In vista degli obiettivi che si prefigge la direttiva ”Bassa tensione” questi componenti
di base, la cui sicurezza può in grandissima misura venire valutata soltanto in funzione
del modo in cui sono incorporati nel materiale elettrico, esulano in quanto tali dal
campo d'applicazione della direttiva. Essi non devono in particolare recare alcun
marchio CE.
Altri componenti elettrici destinati a venire incorporati in materiale elettrico d'altro
genere, per i quali si può tuttavia procedere ad una valutazione della sicurezza12
(come ad esempio alcuni tipi di trasformatori e di motori elettrici) rientrano in quanto
tali nel campo d'applicazione della direttiva e devono recare il marchio CE.
Occorre inoltre non incorrere in malintesi circa il campo d'applicazione della direttiva
ritenendo erroneamente che ne siano esclusi in quanto componenti di base,
componenti quali lampade, aviatori, fusibili, interruttori per uso domestico, elementi
d'impianti elettrici etc. i quali, benché spesso utilizzati in associazione ad altro
materiale elettrico e tali da richiedere una corretta installazione per poter svolgere la
loro funzione, sono essi stessi da considerarsi materiale elettrico a termini della
direttiva.
Il documento (penso lo trovi su internet nel sito dell'UE riguardo la direttiva BT) si intitola
COMMISSIONE EUROPEA
DIREZIONE GENERALE IMPRESE
Mercato unico: quadro legislativo, normazione e nuovo approccio
Industria delle apparecchiature meccaniche, elettrotecniche e terminali radio e di
telecomunicazione
ENTR-G-3/2001/7299
LINEE GUIDA PER L'APPLICAZIONE
DELLA DIRETTIVA DEL CONSIGLIO
73/23/CEE
(Materiale elettrico destinato ad essere adoperato entro taluni limiti di tensione)
Febbraio 2001
io citerei questo documento - punto 9
salutoni
315 1 2 6
Torna a Direttiva Macchine
