Sto usando un PIC 16f1713 ed ho la necessità di configurarlo per avere il clock di 32 MHz con oscillatore interno, sapete aiutarmi?
riporto il datasheet;
- Codice: Seleziona tutto
Internal Oscillator Frequency
Selection
The system clock speed can be selected via software
using the Internal Oscillator Frequency Select bits
IRCF<3:0> of the OSCCON register.
The postscaled output of the 16 MHz HFINTOSC,
500 kHz MFINTOSC, and 31 kHz LFINTOSC connect
to a multiplexer (see Figure 6-1). The Internal Oscillator
Frequency Select bits IRCF<3:0> of the OSCCON
register select the frequency output of the internal
oscillators. One of the following frequencies can be
selected via software:
- 32 MHz (requires 4x PLL)
- 16 MHz
- 8 MHz
- 4 MHz
- 2 MHz
- 1 MHz
- 500 kHz (default after Reset)
- 250 kHz
- 125 kHz
- 62.5 kHz
- 31.25 kHz
- 31 kHz (LFINTOSC)
The IRCF<3:0> bits of the OSCCON register allow
duplicate selections for some frequencies. These
duplicate choices can offer system design trade-offs.
Lower power consumption can be obtained when
changing oscillator sources for a given frequency.
Faster transition times can be obtained between
frequency changes that use the same oscillator source.
6.2.2.6 32 MHz Internal Oscillator
Frequency Selection
The Internal Oscillator Block can be used with the
4x PLL associated with the External Oscillator Block to
produce a 32 MHz internal system clock source. The
following settings are required to use the 32 MHz
internal clock source:
• The FOSC bits in Configuration Words must be
set to use the INTOSC source as the device
system clock (FOSC<2:0> = 100).
• The SCS bits in the OSCCON register must be
cleared to use the clock determined by
FOSC<2:0> in Configuration Words
(SCS<1:0> = 00).
• The IRCF bits in the OSCCON register must be
set to the 8 MHz HFINTOSC set to use
(IRCF<3:0> = 1110).
• The SPLLEN bit in the OSCCON register must be
set to enable the 4x PLL, or the PLLEN bit of the
Configuration Words must be programmed to a
‘1’.
The 4x PLL is not available for use with the internal
oscillator when the SCS bits of the OSCCON register
are set to ‘1x’. The SCS bits must be set to ‘00’ to use
the 4x PLL with the internal oscillator.
Note: When using the PLLEN bit of the
Configuration Words, the 4x PLL cannot
be disabled by software and the SPLLEN
option will not be available.
Questa la mia configurazione:
#pragma config FOSC=INTOSC
#pragma config CP=0
#pragma config CLKOUTEN=1
#pragma config PWRTE=0
#pragma config WDTE=0
#pragma config MCLRE=1
#pragma config FCMEN = 0
#pragma config IESO = 0
#pragma config BOREN=0
#pragma config LVP=0;
OSCCON = 0b11110000;
Sapete dirmi se la configurazione che sto usando è corretta?
