Il pic18f46k22 è collegato tramite il pin 25(TX1) al RX del convertitore seriale-usb (nel mio caso il pin RB7 di un pic18f14k5) e ip pin 26(RX1) al TX del convertitore (RB5).
Ma per fortuna il problema era softwere, ora la funzione echo funziona, ho copiato e riadattato il codice in questa discussione http://www.microchip.com/forums/tm.aspx?m=647984
Non ho ben capito cosa sbagliavo va mesto funziona:
- Codice: Seleziona tutto
#include <stdint.h> /* For uint8_t definition */
#include <stdbool.h> /* For true/false definition */
#include <usart.h>
#include "system.h" /* System funct/params, like osc/peripheral config */
#include "user.h" /* User funct/params, such as InitApp */
void main(void)
char ch;
TRISCbits.TRISC7 = 1; //Defining as per datasheet requirement
TRISCbits.TRISC6 = 1; //Defining as per datasheet requirement
ADCON0bits.ADON = 0;
ANSELCbits.ANSC7 = 0; //0 = Digital input buffer enabled
ANSELCbits.ANSC6 = 0; //0 = Digital input buffer enabled
// 19200 bps 8 bit + 1 stop
Open1USART( USART_TX_INT_OFF &
USART_RX_INT_OFF &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH,
207 );
while (1)
while (!DataRdy1USART());
ch = Read1USART();
Write1USART(ch);
while (Busy1USART());
// putc1USART(getc1USART());
Grazie mille.
Un ultima domanda, questo è il file interrupt.c dei template che crea mplabx
/*Files to Include */
#if defined(__XC)
#include <xc.h> /* XC8 General Include File */
#elif defined(HI_TECH_C)
#include <htc.h> /* HiTech General Include File */
#elif defined(__18CXX)
#include <p18cxxx.h> /* C18 General Include File */
#endif
#if defined(__XC) || defined(HI_TECH_C)
#endif
/* Interrupt Routines */
/* High-priority service */
void interrupt high_isr(void)
#elif defined (__18CXX)
#pragma code high_isr=0x08
#pragma interrupt high_isr
void high_isr(void)
#else
#error "Invalid compiler selection for implemented ISR routines"
#endif
/* This code stub shows general interrupt handling. Note that these
conditional statements are not handled within 3 seperate if blocks.
Do not use a seperate if block for each interrupt flag to avoid run
time errors. */
#if 0
/* TODO Add High Priority interrupt routine code here. */
/* Determine which flag generated the interrupt */
if(<Interrupt Flag 1>)
<Interrupt Flag 1=0>; /* Clear Interrupt Flag 1 */
else if (<Interrupt Flag 2>)
<Interrupt Flag 2=0>; /* Clear Interrupt Flag 2 */
else
/* Unhandled interrupts */
#endif
/* Low-priority interrupt routine */
void low_priority interrupt low_isr(void)
#pragma code low_isr=0x18
#pragma interruptlow low_isr
void low_isr(void)
#else
#endif
time errors. */
#if 0
/* TODO Add Low Priority interrupt routine code here. */
else
#endif
Io ho capito i vari #if defined variano al variare del compilatore, ma cosa fa quando legge #if 0 e chiude con #endif.
Grazie ancora Ciao Ivo
