da
solideo » 11 feb 2017, 6:41
Anchio ho avuto lo stesso inghippo perché l'adattatore I2c me lo sono autocostruito e il problema era la corrispondenza dei pin del display con quegli dell'adattatore.
Il tuo sketch riporta
- Codice: Seleziona tutto
LiquidCrystal_I2C lcd(0x27,16,2);
io per ovviare al problema ho scritto
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x38, 4, 5, 6, 0, 1, 2, 3, 7, POSITIVE);
ti spiego:
il primo valore è l'indirizzo del modulo I2c nel mio caso è 0x38 te 0x27, comunque per essere sicuro dell'indirizzo puoi caricare questo sketch aprire il monitor Seriale e ti restituisce l'indirizzo I2c:
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
void setup()
Wire.begin();
Serial.begin(9600);
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000);
il resto dei numeri corrispondono hai pin dell'integrato , penso un pcf8574, con i rispettivi pin del display quindi il pin enable del display che è il 6 deve corrispondere al P4 dell'integrato , che se è il pcf8574 e il piedino 9, e cosi via l'ultimo valore serve per la retroilluminazione che di solito viene comandata sul pin positivo:
- questo è il mio cablaggio
- pcf8574.png (12.37 KiB) Osservato 6047 volte
Poi nel "Setup" metti :
lcd.begin(16x2); //sedici caratteri 2 righe
Quindi se questo fosse anche il tuo problema ti dovresti mettere con il tester e controllare come sono connessi pin del display con quegli dell'integrato.
