Problema su librerie
[1] Problema su librerie
Messaggioda Foto Utentepapa10 » 25 set 2017, 16:58
Ho un problema sulle librerie sullo sketch sotto postato che non riesco a trovare ed installarle:le librerie sono Adafruit_feather.h e adafruit_aio.h
Codice: Seleziona tutto
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_FeatherOLED.h>
#include <Adafruit_FeatherOLED_WiFi.h>
#include <Adafruit_Sensor.h>
#include <adafruit_feather.h>
#include <adafruit_mqtt.h>
#include <adafruit_aio.h>
#define WLAN_SSID                 "SSID"
#define WLAN_PASS                 "PASSWORD"
#define VBAT_ENABLED              1
#define VBAT_PIN                  PA1
#define SENSOR_TSL2561_ENABLED    0
#if SENSOR_TSL2561_ENABLED
  #include <Adafruit_TSL2561_U.h>
  bool _tslFound = false;
  Adafruit_TSL2561_Unified tsl = Adafruit_TSL2561_Unified(TSL2561_ADDR_FLOAT, 12345);
#endif
#define AIO_ENABLED               0
#define AIO_USERNAME              "...your AIO username (see https://accounts.adafruit.com)..."
#define AIO_KEY                   "...your AIO key..."
#define FEED_VBAT                 "vbat"
#define FEED_TSL2561_LUX          "lux"
AdafruitAIO                        aio(AIO_USERNAME, AIO_KEY);
AdafruitAIOFeedGauge<float>        feedVBAT(&aio, FEED_VBAT);
AdafruitAIOFeedGauge<float>        feedLUX (&aio, FEED_TSL2561_LUX);
Adafruit_FeatherOLED_WiFi  oled = Adafruit_FeatherOLED_WiFi();
    @brief  Connect to the AP
    @return Error code
bool connectAP()
  oled.refreshIcons();
  oled.clearMsgArea();
  oled.println("Connecting to ...");
  oled.println(WLAN_SSID);
  oled.display();
  // Attempt to connect to the AP
  if ( Feather.connect(WLAN_SSID, WLAN_PASS) )
    int8_t rssi = Feather.RSSI();
    uint32_t ipAddress = Feather.localIP();
    oled.setConnected(true);
    oled.setRSSI(rssi);
    oled.setIPAddress(ipAddress);
  else
    // Display the error message
    err_t err = Feather.errno();
    oled.setConnected(false);
    oled.println("Connection Error:");
    switch (err)
      case ERROR_WWD_ACCESS_POINT_NOT_FOUND:
        // SSID wasn't found when scanning for APs
        oled.println("Invalid SSID");
        break;
      case ERROR_WWD_INVALID_KEY:
        // Invalid SSID passkey
        oled.println("Invalid Password");
        break;
      default:
        // The most likely cause of errors at this point is that
        // you are just out of the device/AP operating range
        oled.print(Feather.errno());
        oled.print(":");
        oled.println(Feather.errstr());
        oled.refreshIcons(); // Refresh icons in case the text ran over
        break;
    oled.display();
    // Return false to indicate that we received an error (available in feather.errno)
    return false;
  return true;
Ultima modifica di Foto Utentewall87 il 25 set 2017, 16:59, modificato 1 volta in totale.
Motivazione: Titolo in minuscolo
Foto Utentepapa10
71 1 3 4
[2] Re: Problema su librerie
Messaggioda Foto UtenteMassimoB » 24 ott 2017, 1:46
probabilmente non le hai incluse nel progetto
MCSA Windows Server 2012 R2
Foto UtenteMassimoB
14,2k 6 12 13
Expert free
[3] Re: Problema su librerie
Messaggioda Foto Utentepapa10 » 24 ott 2017, 7:21
Ho detto che non riesco a trovarle ,quindi come faccio ad installarle?
Foto Utentepapa10
71 1 3 4
[4] Re: Problema su librerie
Messaggioda Foto UtenteShides » 3 nov 2017, 10:27
hai seguito la guida fornita su Adafruit per aggiungere il supporto a board di terze parti sull'IDE Arduino?
Seguendo le istruzioni in questo tutorial (sono tre paginette) dovresti risolvere O_/
https://learn.adafruit.com/add-boards-a ... 4/overview
Foto UtenteShides
0 1
[5] Re: Problema su librerie
Messaggioda Foto Utentepapa10 » 3 nov 2017, 12:28
grazie
Foto Utentepapa10
71 1 3 4
Torna a Arduino
