- Codice: Seleziona tutto
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_FeatherOLED.h>
#include <Adafruit_FeatherOLED_WiFi.h>
#include <Adafruit_Sensor.h>
#include <adafruit_feather.h>
#include <adafruit_mqtt.h>
#include <adafruit_aio.h>
#define WLAN_SSID "SSID"
#define WLAN_PASS "PASSWORD"
#define VBAT_ENABLED 1
#define VBAT_PIN PA1
#define SENSOR_TSL2561_ENABLED 0
#if SENSOR_TSL2561_ENABLED
#include <Adafruit_TSL2561_U.h>
bool _tslFound = false;
Adafruit_TSL2561_Unified tsl = Adafruit_TSL2561_Unified(TSL2561_ADDR_FLOAT, 12345);
#endif
#define AIO_ENABLED 0
#define AIO_USERNAME "...your AIO username (see https://accounts.adafruit.com)..."
#define AIO_KEY "...your AIO key..."
#define FEED_VBAT "vbat"
#define FEED_TSL2561_LUX "lux"
AdafruitAIO aio(AIO_USERNAME, AIO_KEY);
AdafruitAIOFeedGauge<float> feedVBAT(&aio, FEED_VBAT);
AdafruitAIOFeedGauge<float> feedLUX (&aio, FEED_TSL2561_LUX);
Adafruit_FeatherOLED_WiFi oled = Adafruit_FeatherOLED_WiFi();
@brief Connect to the AP
@return Error code
bool connectAP()
oled.refreshIcons();
oled.clearMsgArea();
oled.println("Connecting to ...");
oled.println(WLAN_SSID);
oled.display();
// Attempt to connect to the AP
if ( Feather.connect(WLAN_SSID, WLAN_PASS) )
int8_t rssi = Feather.RSSI();
uint32_t ipAddress = Feather.localIP();
oled.setConnected(true);
oled.setRSSI(rssi);
oled.setIPAddress(ipAddress);
else
// Display the error message
err_t err = Feather.errno();
oled.setConnected(false);
oled.println("Connection Error:");
switch (err)
case ERROR_WWD_ACCESS_POINT_NOT_FOUND:
// SSID wasn't found when scanning for APs
oled.println("Invalid SSID");
break;
case ERROR_WWD_INVALID_KEY:
// Invalid SSID passkey
oled.println("Invalid Password");
break;
default:
// The most likely cause of errors at this point is that
// you are just out of the device/AP operating range
oled.print(Feather.errno());
oled.print(":");
oled.println(Feather.errstr());
oled.refreshIcons(); // Refresh icons in case the text ran over
break;
oled.display();
// Return false to indicate that we received an error (available in feather.errno)
return false;
return true;
Problema su librerie
5 messaggi
Ho un problema sulle librerie sullo sketch sotto postato che non riesco a trovare ed installarle:le librerie sono Adafruit_feather.h e adafruit_aio.h
Ultima modifica di
wall87 il 25 set 2017, 16:59, modificato 1 volta in totale.
Motivazione: Titolo in minuscolo
probabilmente non le hai incluse nel progetto
MCSA Windows Server 2012 R2
hai seguito la guida fornita su Adafruit per aggiungere il supporto a board di terze parti sull'IDE Arduino?
Seguendo le istruzioni in questo tutorial (sono tre paginette) dovresti risolvere
https://learn.adafruit.com/add-boards-a ... 4/overview
5 messaggi
