vi allego il sorgente
- Codice: Seleziona tutto
; 8 Channel PWM LED Chaser for PIC 16F628/A *
; Filename: pro481v207.asm *
; Date: 27/10/2010 *
; File Version: 2.0.7 *
; Author: Pete Griffiths *
; Company: http://picprojects.org.uk *
; Written and assmbled under MPLAB Version 8.20 *
; Before assembling code set correct PIC processor in MPLAB *
; from menu option Configure - Select Device *
; Now works with 16F84A, 16F627/628 16F627A/628A and 16F88 *
; The devices with 1K program memory (16F84A, 16F627/627A *
; will need some Sequences in pwmc_SeqData.inc file removing *
; to fit the code in their limited memory. *
; 27/10/2010 *
; PWM LED Chaser variant code for use with PCB480C only *
; Notes: *
; 1. PIC 16F628A datasheet can be downloaded from *
; http://ww1.microchip.com/downloads/en/DeviceDoc/40044b.pdf *
; 2. See also MPASM User Guide(UG) which can be downloaded from: *
; http://ww1.microchip.com/downloads/en/DeviceDoc/33014J.pdf *
; http://picprojects.org.uk/projects/ledchaser/ *
; 3. This code uses Pseudo-instructions listed in the MPASM User *
; guide, Part 4, Appendix A.5 *
; 4. For list of Radix types see MPASM UG Section 3.4, Table 3-3 *
ifdef __16F88
#include <p16f88.inc>
;Program Configuration Register 1
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_ON & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
;Program Configuration Register 2
__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
#define T0IF TMR0IF
#define T0IE TMR0IE
endif
ifdef __16F628A
#include <p16f628A.inc> ; Standard include file
; defines processor specific variable definitions
; See MPASM UG Section 4.41
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
; and also see MPASM UG Section 4.12
__CONFIG _CP_OFF & _WDT_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF
endif
ifdef __16F628
#include <p16f628.inc>
endif
ifdef __16F84A
; **** 16F84A only has 1K of program memory - the default pwm_SeqData.inc file ****
; **** will not fit into the available memory, you must remove some of the ****
; **** the sequence data from the file before assembling the code ****
#include <p16f84a.inc>
__CONFIG _CP_OFF & _WDT_ON & _PWRTE_ON & _HS_OSC
; Code protect off
; Watch Dog timer off
; Power-up timer delay on
; change to _RC_OSC for resistor/capacitor
; change to _XT_OSC for crystal/resonator <3.5Mhz
; change to _HS_OSC for high speed crystal/resonator >3.5Mhz
endif
; Suppress specific warning messages
; see MPASM UG Section 4.29 for errorlevel directive
; see MPASM UG Section 8.4 for assembler message descriptions
errorlevel -302 ; suppress banksel warning messages during assembly
; define variables in General Purpose Register (GPR) memory
; See MPASM UG Section 4.8
; note: 16F84A GPR start at 0x0C but most other mid-range PICs start at 0x20
; We use 0x20 here for compatibilty with newer PICs
cblock 0x20
firstGPR:0 ; mark start of GPR memory used
state ; used by function state selector
copyPORTB ; working variable, holds copy of PORTB
vc0,vc1,vc2,vc3,vc4 ; vertical counter bits
hiReload ; vertical counter reload hi
loReload ; vertical counter reload lo
PWM ; PWM counter
holdTime ; sequence line hold time
repeatCount ; repeat seqeunce count
RandMask ; mask to AND random number with
seqIdxLo ; Lo byte address index pointer to start of selected sequence
seqIdxHi ; Hi byte address index pointer to start of selected sequence
seqTotal ; Total number of sequences in data
seqMatch ; working variable
seqCount ; working variable
forward ; working regsiter for mirroring data
reverse ; working regsiter for mirroring data
reloadTemp ; temporary holding variable for loReload
tick ; timer0 ticks
swTimer ; switch hold down timer
flags ; function flags register
mode ; mode flags register
indexLo ; Lo byte sequence line data address pointer
indexHi ; Hi byte sequence line data address pointer
save_W ; save W during interupt
save_Status ; save STATUS during interupt
save_PCLATH ; save PCLATH
saveModeTimerL ; holdoff timer for saving opmode to EEPROM high
saveModeTimerH ; holdoff timer for saving opmode to EEPROM low
eesave_W ; temp register used in EEPROM routings
LFSRH ; Random number shift regsiter high byte
LFSRL:0 ; Random number shift register low byte
lastGPR ; mark last GPR register used
; (required by GPR initialisation code)
endc
; EEPROM data
; ; program parameters
org 0x2100
de .0
de .1
de .0
; embed firmware release info
de " PRO481 PWM LED Chaser "
de " V2.0.7 "
de " 27/10/2010 "
de " picprojects.org.uk "
; Define bank select pseudo instructions to make code more readable
#define bank0 bcf STATUS,RP0 ; Sel Bank 0
#define bank1 bsf STATUS,RP0 ; Sel Bank 1
; See MPASM UG Secdtion 4.27 for definition of equ directive
switch equ 4 ; Port bit switch connected to
cSAVETIME EQU d'4' ; holdoff timer constant for saving EEPROM data
cTIMER EQU d'157'
cTICKS EQU d'50'
; 4Mhz oscillator clock, gives TMR0 clock = 1Mhz.
; Write to timer0 inhibits clock for 2 clock cycles
; TMR0 prescaler of 1:2 gives
; 1Mhz / ((256-157+2) x 2) = 5Khz = 0.2mS
; 50 x 0.2mS = 10mS
; So the sequence hold time will be 10mS x holdTime, giving a range of
; 1 = 10mS thru 254 = 2.54S
; remember that a holdtime value of 255 indicates the end of the sequence so DON'T USE IT
; define flag bits
fHoldTimeout EQU 0 ; flag set by ISR, cleared by Table Lookup function
fSwitch EQU 1 ; flag
fsetupRun EQU 2 ; 0=run mode / 1=setup mode
fTick EQU 3 ; timer tick flag
fSaveMode EQU 4 ; set indicates opmode needs writing to EEPROM, clear indicates no data to write
; 5
fMirrorData EQU 6 ; flag set, Table read reverses bits in data word [** This flag must be Bit 6 **]
fMirrorNext EQU 7 ; flag tells code current sequence should be mirrored next time
#define canMirror 1<<fMirrorData ; Don't change the position of this bit, sequence data expects it here
; define mode bits
modeSeq EQU 0
modeRan EQU 1
modeMan EQU 2
modeSleep EQU 3
; Program code starts here
; See MPASM UG Section 1.7.1, and Example 1-1
; Labels Mnemonics Operands Comments
; Directives
; Macros
RESET_VECTOR org 0x000 ; see MPASM UG Section 4.50
goto START ; START label is in pwmc_start.inc
INTERRUPT_V org 0x004 ; Interrupt handler code must follow this origin statement
#include pro481_inth.inc ; include Interrupt Handler code block
#include pro481_statef.inc ; include main state function code block (must reside in page 0)
#include pro481_start.inc ; include reset and initialisation code
#include pro481_functions.inc ; include all program functions
#include pro481_SeqMacro.inc ; include MACRO definitions for sequence data
; used for creating sequence data tables
; DO NOT CHANGE OR REMOVE this label
SeqBaseAddr ; label marks base address for start of sequence data.
; Include your sequence data file(s) here
#include pro481_SeqData.inc ; file containg sequence data
;#include pro481_xmastree.inc ; alternate data for use with xmas tree PCB
; Do not remove this instruction
_markLast retlw .255 ; Ensure last sequence is marked
end ; end of instructions, always needed
