MarkyMark ha scritto:C'è questo package (che non ho mai usato)
Io lo uso
http://www.texample.net/tikz/examples/
Tenta se riesci di usare software per disegni vettoriali come Fidocadj o Inkscape, evita di usare bitmap ameno che non sei obbligato.
. Il tutto permette di avere la figura come vettoriale (incluse le scritte e i simboli) nel pdf finale.
ed e' un po' macchinoso (il package va installato manualmente e richiede m4 e dpic) ma io mi ci trovo benone.#!/bin/sh
FIDOCADJ_PATH="_path_to_fidocadj_/fidocadj.jar"
java -jar $FIDOCADJ_PATH -n -c r2.0 pgf stochastical_signal_realizations.pgf FidoCadJ/stochastical_signal_realizations.fcd
java -jar $FIDOCADJ_PATH -n -c r1.35 pgf negative_positive_freq.pgf FidoCadJ/negative_positive_freq.fcd
java -jar $FIDOCADJ_PATH -n -c r2 pgf noise_resistance.pgf FidoCadJ/noise_resistance.fcd
java -jar $FIDOCADJ_PATH -n -c r1.5 pgf real_filter_noise.pgf FidoCadJ/real_filter_noise.fcd
java -jar $FIDOCADJ_PATH -n -c r2 pgf summing_noises.pgf FidoCadJ/summing_noises.fcd
java -jar $FIDOCADJ_PATH -n -c r2 pgf noise_model_aop.pgf FidoCadJ/noise_model_aop.fcd
java -jar $FIDOCADJ_PATH -n -c r1.5 pgf emc_common_impedance.pgf FidoCadJ/emc_common_impedance.fcd
java -jar $FIDOCADJ_PATH -n -c r1.5 pgf emc_common_impedance_solution.pgf FidoCadJ/emc_common_impedance_solution.fcd
java -jar $FIDOCADJ_PATH -n -c r1.4 pgf emc_magnetic_coupling.pgf FidoCadJ/emc_magnetic_coupling.fcd
java -jar $FIDOCADJ_PATH -n -c r1.4 pgf emc_magnetic_coupling_solution.pgf FidoCadJ/emc_magnetic_coupling_solution.fcd
java -jar $FIDOCADJ_PATH -n -c r1.4 pgf emc_electric_coupling.pgf FidoCadJ/emc_electric_coupling.fcd
java -jar $FIDOCADJ_PATH -n -c r1.4 pgf emc_electric_coupling_solution.pgf FidoCadJ/emc_electric_coupling_solution.fcd
java -jar $FIDOCADJ_PATH -n -c r1.4 pgf noninverting_amplifier.pgf FidoCadJ/noninverting_amplifier.fcd
java -jar $FIDOCADJ_PATH -n -c r1.4 pgf noninverting_amplifier_term_c2.pgf FidoCadJ/noninverting_amplifier_term_c2.fcd
java -jar $FIDOCADJ_PATH -n -c r1.25 pgf noise_diff_3amp.pgf FidoCadJ/noise_diff_3amp.fcd\begin{table}
\resizebox{\textwidth}{!}{
\begin{tabular}{lcc}
\hline
& \textbf{Issue} & \textbf{Possible solutions}\\
\hline
\rotatebox{90}{\hspace{2.5em}A. Common impedance} &
{\tiny \input{bruit/emc_common_impedance.pgf}} &
{\tiny \input{bruit/emc_common_impedance_solution.pgf}} \\
\hline
\rotatebox{90}{\hspace{2.5em}B. Inductive coupling} &
{\tiny \input{bruit/emc_magnetic_coupling.pgf}} &
{\tiny \input{bruit/emc_magnetic_coupling_solution.pgf}} \\
\hline
\rotatebox{90}{\hspace{3em}C. Capacitive coupling} &
{\tiny \input{bruit/emc_electric_coupling.pgf}} &
{\tiny \input{bruit/emc_electric_coupling_solution.pgf}} \\
\hline
\end{tabular}
\caption{Examples of low-frequency coupling between circuits with possible solutions.}
\label{tab_emc_issues}
\end{table}
Visitano il forum: Nessuno e 160 ospiti
