Problema a far funzionare l'MCP4728
GioArca67 ha scritto:Ma cosa devi fare? Perché non includi la libreria invece di copiare pezzettini?
Cosa devo includere di preciso? Non so cosa devo mettere dopo "#include"
Ho usato questo codice:
e questo è l'errore:
- Codice: Seleziona tutto
#include <Wire.h>
#include <MCP4728.h>
MCP4728 mcp;
void setup(void) {
Serial.begin(115200);
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("Adafruit MCP4728 test!");
// Try to initialize!
if (!mcp.begin(0x60)) { //indirizzo del MCP4728, da 0x60 a 0x68, default se omesso a 0x60
Serial.println("Failed to find MCP4728 chip");
while (1) {
delay(10);
Serial.println("MCP4728 chip found");
mcp.setChannelValue(MCP4728_CHANNEL_A, 4095);
mcp.setChannelValue(MCP4728_CHANNEL_B, 2048);
mcp.setChannelValue(MCP4728_CHANNEL_C, 1024);
mcp.setChannelValue(MCP4728_CHANNEL_D, 0);
Arduino:1.8.10 (Linux), Scheda:"Arduino Yún"
/home/fabio/Scrivania/fade_2/fade_2.ino: In function 'void setup()':
fade_2:15:12: error: 'class MCP4728' has no member named 'begin'
fade_2:22:7: error: 'class MCP4728' has no member named 'setChannelValue'
fade_2:22:23: error: 'MCP4728_CHANNEL_A' was not declared in this scope
/home/fabio/Scrivania/fade_2/fade_2.ino:22:23: note: suggested alternative: 'MCP4728_H'
MCP4728_H
fade_2:23:7: error: 'class MCP4728' has no member named 'setChannelValue'
fade_2:23:23: error: 'MCP4728_CHANNEL_B' was not declared in this scope
/home/fabio/Scrivania/fade_2/fade_2.ino:23:23: note: suggested alternative: 'MCP4728_H'
MCP4728_H
fade_2:24:7: error: 'class MCP4728' has no member named 'setChannelValue'
fade_2:24:23: error: 'MCP4728_CHANNEL_C' was not declared in this scope
/home/fabio/Scrivania/fade_2/fade_2.ino:24:23: note: suggested alternative: 'MCP4728_H'
MCP4728_H
fade_2:25:7: error: 'class MCP4728' has no member named 'setChannelValue'
fade_2:25:23: error: 'MCP4728_CHANNEL_D' was not declared in this scope
/home/fabio/Scrivania/fade_2/fade_2.ino:25:23: note: suggested alternative: 'MCP4728_H'
MCP4728_H
Più di una libreria trovata per "Wire.h"
Usata: /home/fabio/.arduino15/packages/arduino/hardware/avr/1.8.3/libraries/Wire
Più di una libreria trovata per "MCP4728.h"
Usata: /home/fabio/Arduino/libraries/MCP4728-master
exit status 1
Prova questo
#include <Wire.h>
#include "MCP4728.h"
MCP4728 dac;
void setup()
Serial.begin(115200); // initialize serial interface for print()
Wire.begin();
dac.attach(Wire, 14);
dac.readRegisters();
dac.selectVref(MCP4728::VREF::VDD, MCP4728::VREF::VDD, MCP4728::VREF::INTERNAL_2_8V, MCP4728::VREF::INTERNAL_2_8V);
dac.selectPowerDown(MCP4728::PWR_DOWN::GND_100KOHM, MCP4728::PWR_DOWN::GND_100KOHM, MCP4728::PWR_DOWN::GND_500KOHM, MCP4728::PWR_DOWN::GND_500KOHM);
dac.selectGain(MCP4728::GAIN::X1, MCP4728::GAIN::X1, MCP4728::GAIN::X2, MCP4728::GAIN::X2);
dac.analogWrite(MCP4728::DAC_CH::A, 111);
dac.analogWrite(MCP4728::DAC_CH::B, 222);
dac.analogWrite(MCP4728::DAC_CH::C, 333);
dac.analogWrite(MCP4728::DAC_CH::D, 444);
dac.enable(true);
printStatus();
delay(5000);
void loop()
static int count = 0;
if (++count > 4000) count = 0;
dac.analogWrite(count, count, count, count);
delay(10);
printStatus();
void printStatus()
Serial.println("NAME Vref Gain PowerDown DACData");
for (int i = 0; i < 4; ++i)
Serial.print("DAC");
Serial.print(i, DEC);
Serial.print(" ");
Serial.print(" ");
Serial.print(dac.getVref(i), BIN);
Serial.print(" ");
Serial.print(dac.getGain(i), BIN);
Serial.print(" ");
Serial.print(dac.getPowerDown(i), BIN);
Serial.print(" ");
Serial.println(dac.getDACData(i), DEC);
Serial.print("EEPROM");
Serial.print(" ");
Serial.print(dac.getVref(i, true), BIN);
Serial.print(" ");
Serial.print(dac.getGain(i, true), BIN);
Serial.print(" ");
Serial.print(dac.getPowerDown(i, true), BIN);
Serial.print(" ");
Serial.println(dac.getDACData(i, true), DEC);
Serial.println(" ");
