ho inserito il secondo MCP4728 con lo scopo di comandare gli altri TDA.
Se inserisco il seguente codice:
- Codice: Seleziona tutto
#include <Wire.h>
int num=0;
void setup()
Wire.begin(0x60);
Serial.begin(9600);
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
delay(500);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println(num);
++num;
else
Serial.println("done\n");
Facendo una scansione di un solo MCP (quello nuovo appena arrivato) senza collegare l'altro mi da come risultato che lo rileva senza problemi, quindi funziona.
Se inserisco il secondo MCP e carico il seguente codice:
#include <MD_AD9833.h>
#include <SPI.h>
#include <Adafruit_MCP4728.h>
#include <Wire.h>
#include <Adafruit_BusIO_Register.h>
#include <TimerOne.h>
Adafruit_MCP4728 mcp;
Adafruit_MCP4728 mcp2;
void play(float fO, int volA, char ta, float fA, int volB, char tb, float fB, int volC, char tc);
void read_USB();
// Pins for SPI comm with the AD9833 IC
#define DATA 11 ///< SPI Data pin number
#define CLK 7 ///< SPI Clock pin number
#define FSYNC 6 //(FSYNC in AD9833 usage)
#define FSYNC1 5
#define FSYNC2 2
#define FSYNC3 3
#define FSYNC4 1
#define FSYNC5 0
int x;
int vol=2100;
float att=0;
float sustain=1000;
float decay=1;
int volmaster=4000;
#define MAX_BUFFER 64
char buffer[MAX_BUFFER];
int elemento_buffer;
MD_AD9833 O(DATA, CLK, FSYNC);
MD_AD9833 A(DATA, CLK, FSYNC1);
MD_AD9833 B(DATA, CLK, FSYNC2);
MD_AD9833 C(DATA, CLK, FSYNC3);
MD_AD9833 D(DATA, CLK, FSYNC4);
MD_AD9833 E(DATA, CLK, FSYNC5);
void setup(void)
O.begin();
A.begin();
B.begin();
C.begin();
D.begin();
E.begin();
Serial.begin(115200);
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("OK!");
// Try to initialize!
if (!mcp.begin(0x60)) {
Serial.println("Failed to find MCP4728 chip1");
while (1) {
delay(10);
if (!mcp2.begin(0x61)) {
Serial.println("Failed to find MCP4728 chip2");
while (1) {
delay(10);
mcp.begin(0x60);
mcp2.begin(0x61);
//Timer1.initialize(2000000); //testa se ci sono comandi sulla USB ogni 1msec
//Timer1.attachInterrupt(read_USB); // read USB to run every 0.15 seconds
void loop()
ottengo il seguente messaggio:
OK!
Nessuno mi puo' aiutarea capire perché succede questo?
Evidentemente devo configurare il secondo MCP in modo che risponda sulla porta 0x61, ma non so come fare.
