LMC555 per riparare luci natalizie
Complimenti
frankis sei sulla buona strada.
Qui c'è qualche video interessante.
viewtopic.php?f=21&t=91428&hilit=+Arduino
Questa è la versione senza commenti, se qualcuno preferisce un codice più compatto:
- Codice: Seleziona tutto
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <avr/interrupt.h>
const byte pinA = 3;
const byte pinB = 9;
const byte buttonPin = 2;
const unsigned long msCoeff = 1000;
const unsigned long runDuration = 6 * msCoeff * 3600;
const unsigned long sleepDuration = 18 * msCoeff * 3600;
volatile bool systemAwake = true;
volatile unsigned long lastWakeTime = 0;
byte sequenceNumber = 1;
void setup()
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
PCICR |= (1 << PCIE2);
PCMSK2 |= (1 << (buttonPin - 0));
lastWakeTime = millis();
ISR(PCINT2_vect)
if (!digitalRead(buttonPin))
systemAwake = true;
sleep_disable();
ISR(WDT_vect)
void loop()
sequences();
void testAwake()
if ((millis() - lastWakeTime) >= runDuration)
enterSleep(false);
return;
void enterSleep(bool sleepForever)
digitalWrite(pinA, LOW);
digitalWrite(pinB, LOW);
cli();
MCUSR &= ~(1 << WDRF);
WDTCSR |= (1 << WDCE) | (1 << WDE);
WDTCSR = (1 << WDCE) | (1 << WDP3) | (1 << WDP0);
WDTCSR |= _BV(WDIE);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sei();
systemAwake = false;
unsigned long sleptTime = 0;
while (sleptTime < sleepDuration)
sleep_mode();
if (systemAwake) break;
if (!sleepForever) sleptTime += 8000;
sleep_disable();
systemAwake = true;
bool readButton()
unsigned long currentTime = millis();
static bool buttonPressed = false;
static unsigned long lastDebounceTime = 0;
const unsigned long debouncewaitMsec = 50;
bool reading = !digitalRead(buttonPin);
if ((currentTime - lastDebounceTime) > debouncewaitMsec)
if (reading != buttonPressed)
buttonPressed = reading;
if (buttonPressed)
sequenceNumber++;
return true;
lastDebounceTime = currentTime;
return false;
bool waitMsec(int milliseconds)
testAwake();
while (millis() - currentTime < milliseconds)
if (readButton()) return true;
return false;
void sequences()
switch (sequenceNumber)
case 1:
if(scrollingEffect()) break;
if(alternateBlinkingEffect()) break;
if(progressiveLightingEffect()) break;
if(waveEffect()) break;
if(randomBlinkingEffect()) break;
if(rapidSequenceEffect()) break;
if(fadePinA()) break;
if(fadePinB()) break;
if(fadeEffect()) break;
if(strobeEffect()) break;
if(breathingEffect()) break;
if(runningEffect()) break;
if(waterfallEffect()) break;
if(meteorShowerEffect()) break;
if(fireflyEffect()) break;
if(rainbowFadeEffect()) break;
if(twinkleEffect()) break;
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
while (!digitalRead(buttonPin));
enterSleep(true);
sequenceNumber = 1;
break;
default:
sequenceNumber = 1;
bool scrollingEffect()
digitalWrite(pinA, HIGH);
if (waitMsec(300)) return true;
digitalWrite(pinB, HIGH);
return false;
bool alternateBlinkingEffect()
for (byte i = 0; i < 5; i++)
if (waitMsec(500)) return true;
return false;
bool progressiveLightingEffect()
for (byte i = 0; i < 20; i++)
if (waitMsec(255)) return true;
if (waitMsec(30)) return true;
return false;
bool waveEffect()
for (byte j = 0; j < 20; j++)
if (waitMsec(100)) return true;
return false;
bool randomBlinkingEffect()
for (byte i = 0; i < 30; i++)
if (random(10) == 0)
else
return false;
bool rapidSequenceEffect()
for (byte i = 0; i < 40; i++)
if (waitMsec(50)) return true;
return false;
bool fadePinA()
for (int brightness = 0; brightness <= 255; brightness++)
analogWrite(pinA, brightness);
if(waitMsec(10)) return true;
for (int brightness = 255; brightness >= 0; brightness--)
return false;
bool fadePinB()
analogWrite(pinB, brightness);
return false;
bool fadeEffect()
analogWrite(pinB, constrain(255 - brightness, 0, 255));
return false;
bool strobeEffect()
if (i % 2 == 0)
else
return false;
bool breathingEffect()
static int brightness = 0;
static int fadeAmount = 1;
for (int i = 0; i < 512; i++)
analogWrite(pinB, 255 - brightness);
brightness += fadeAmount;
if (brightness <= 0 || brightness >= 255)
fadeAmount = -fadeAmount;
if (waitMsec(10)) return true;
return false;
bool runningEffect()
for (byte i = 0; i < 3; i++)
if (waitMsec(100)) break;
return false;
bool waterfallEffect()
return false;
bool meteorShowerEffect()
for (int i = 0; i < 5; i++)
return false;
bool fireflyEffect()
for (int i = 0; i < 10; i++)
int duration = random(50, 200);
if(waitMsec(duration)) return true;
return false;
bool rainbowFadeEffect()
return false;
bool twinkleEffect()
for (int i = 0; i < 20; i++)
if (random(2) == 0)
else
if (waitMsec(random(100, 500))) return true;
return false;
Certo che se dovevi realizzare tutti quegli effetti luminosi solo con l’elettronica, dovevi mettercene di componenti.
Ma funziona in modo stabile? Può essere replicato senza modifiche software?
corneliofallaci
1.470 1 4 7 - Stabilizzato
A ci credo. Poi le aggiunte degli effetti sono gratis, basta aggiungere qualche riga di programma.
Quasi quasi lo faccio anch’io. Ho un controller simile che è funzionante ma per provare a lavorarci mi basta scollegare la catena led senza rischi per il controller.
corneliofallaci
corneliofallaci ha scritto:A ci credo. Poi le aggiunte degli effetti sono gratis, basta aggiungere qualche riga di programma.
Si adesso l’unica elettronica presente è la schedina Arduino Pro Mini e gestisce tutto il programma.
Il funzionamento ormai è invariato da molti giorni e la replicazione è garantita senza problemi. Il programma l’ho installato più volte e non ha mai saltato un’istruzione. Credo che le uniche modifiche utili potrebbero riguardare l’espansione degli effetti luminosi.
Visitano il forum: Google [Bot] e 106 ospiti
