Salve, stavo cercando di creare la netlist per fare il layout della board tramite allegro. Ho fatto il circuito, l ho simulato e ho fatto il design rules check ed è tutto ok, ma quando vado a creare la netlist mi esce:
Error (orcap_32042):netlist failed.Please refer to session log or netlist log for details.
Inoltre : { Using PSTWRITER 16.6.0 d001Jun-17-2015 at 07:26:04 }
#1 ERROR(ORCAP-36032): Duplicate Reference Designator U3A: halfadd, halfadd (6.20, 1.60).
#2 ERROR(ORCAP-36032): Duplicate Reference Designator U1A: halfadd, halfadd (2.20, 2.00).
#3 ERROR(ORCAP-36032): Duplicate Reference Designator U1B: halfadd, halfadd (3.10, 2.00).
#4 ERROR(ORCAP-36032): Duplicate Reference Designator U1A: fulladd, fulladd (5.90, 1.20).
#5 ERROR(ORCAP-36032): Duplicate Reference Designator U2B: halfadd, halfadd (4.50, 1.20).
#6 ERROR(ORCAP-36032): Duplicate Reference Designator U2C: halfadd, halfadd (6.00, 2.80).
#7 ERROR(ORCAP-36032): Duplicate Reference Designator U2A: halfadd, halfadd (4.50, 2.30).
#8 ERROR(ORCAP-36046): Conflicting number of parts per package (4) for U1A: fulladd, fulladd (5.90, 1.20)
#9 ERROR(ORCAP-36036): Multiple pin 1's which have different nets connected for U3: halfadd, halfadd (6.20, 1.60).
Check for incorrect packaging of all devices in U3.
#10 ERROR(ORCAP-36036): Multiple pin 2's which have different nets connected for U3: halfadd, halfadd (6.20, 1.60).
#11 ERROR(ORCAP-36036): Multiple pin 3's which have different nets connected for U3: halfadd, halfadd (6.20, 1.60).
#12 ERROR(ORCAP-36036): Multiple pin 1's which have different nets connected for U1: halfadd, halfadd (2.20, 2.00).
Check for incorrect packaging of all devices in U1.
#13 ERROR(ORCAP-36036): Multiple pin 2's which have different nets connected for U1: halfadd, halfadd (2.20, 2.00).
#14 ERROR(ORCAP-36036): Multiple pin 3's which have different nets connected for U1: halfadd, halfadd (3.10, 2.00).
#15 ERROR(ORCAP-36036): Multiple pin 4's which have different nets connected for U1: halfadd, halfadd (3.10, 2.00).
#16 ERROR(ORCAP-36036): Multiple pin 1's which have different nets connected for U1: fulladd, fulladd (5.90, 1.20).
#17 ERROR(ORCAP-36036): Multiple pin 2's which have different nets connected for U1: fulladd, fulladd (5.90, 1.20).
#18 ERROR(ORCAP-36036): Multiple pin 3's which have different nets connected for U1: fulladd, fulladd (5.90, 1.20).
#19 ERROR(ORCAP-36036): Multiple pin 4's which have different nets connected for U2: halfadd, halfadd (4.50, 1.20).
Check for incorrect packaging of all devices in U2.
#20 ERROR(ORCAP-36036): Multiple pin 5's which have different nets connected for U2: halfadd, halfadd (4.50, 1.20).
#21 ERROR(ORCAP-36036): Multiple pin 6's which have different nets connected for U2: halfadd, halfadd (4.50, 1.20).
#22 ERROR(ORCAP-36036): Multiple pin 9's which have different nets connected for U2: halfadd, halfadd (6.00, 2.80).
#23 ERROR(ORCAP-36036): Multiple pin 10's which have different nets connected for U2: halfadd, halfadd (6.00, 2.80).
#24 ERROR(ORCAP-36036): Multiple pin 8's which have different nets connected for U2: halfadd, halfadd (6.00, 2.80).
#25 ERROR(ORCAP-36036): Multiple pin 1's which have different nets connected for U2: halfadd, halfadd (4.50, 2.30).
#26 ERROR(ORCAP-36036): Multiple pin 2's which have different nets connected for U2: halfadd, halfadd (4.50, 2.30).
#27 ERROR(ORCAP-36036): Multiple pin 3's which have different nets connected for U2: halfadd, halfadd (4.50, 2.30).
#28 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
Ma non capisco a cosa sono dovuti questi problemi. Spero che qualcuno mi possa aiutare. Grazie mille in anticipo.
Error (orcap_32042)
5 messaggi
PIERGIUSEPPE90
1 3 - CRU - Account cancellato su Richiesta utente
Hai un duplicate packaging error -> hai chiamato due componenti con lo stesso nome.
Prima di compilare la Netlist devi fare Annotate, mi sembra si trovi sotto il menu Tools, se non ricordo male.
Pietro.
Pietro.
PietroBaima
90,7k 7 12 13 - G.Master EY
Ho fatto l'annotate:
* Performing annotation.
ERROR(ORCAP-1377): Component U3A has different common pin connection for two instances and hence packaged separately.
INFO(ORCAP-1378): LAST USED REFERENCES
DSTM3
HALFADD_A1
U5
HALFADD_B1
J3
V1
INFO(ORCAP-1379): Done updating part references
Non trovo niente che abbia lo stesso nome, né il problema relativo al componente U3A.
DSTM3
HALFADD_A1
U5
HALFADD_B1
J3
V1
PIERGIUSEPPE90
Ce l ho fatta. Non mi da nessun errore e ho creato la netlist. Il problema era che non non avevo messo il net alias in un filo collegato a massa e ora il problema non c'è più. Non capisco cosa c'entra quell'errore che mi dava. Comunque io metto sto filo a massa ma non so il perché, ho fatto un full adder, e all'inerno di ognuno dei due half adder ho messo un ground e un pezzettino di filo col net alias GND ma non so a cosa serve. Il professore ce lo fece mettere nel primo progetto senza mai spiegarci a cosa serva. Potresti chiarirmi le idee? Grazie
PIERGIUSEPPE90
AH, ho capito.
Il simulatore richiede che ci sia sempre un nodo chiamato GND.
Ha bisogno di sapere chi sia il suo riferimento interno da porre a 0V.
Pietro.
PS_OT: sto cominciando a sviluppare un certo odio verso i professori faciloni (ma non è colpa solo tua, sono diversi thread a cui partecipo ultimamente in cui si parla di professori... un po' strani!)
Pietro.
PietroBaima
5 messaggi
pigreco]=π
