modifica firmware
[1] modifica firmware
Messaggioda Foto Utentesteorai » 14 dic 2017, 19:33
ciao a tutti ho realizzato questo circuito trovato sul sito http://picprojects.org.uk/projects/480/pro481/#Description ho notato la velocità con la quale viene eseguita e volevo rallentare i vari giochi ma aprendo il file asm mi sono trovato un sorgente che non capisco, pensavo di trovarmi davanti ad un sorgente tipo basic che in qualche maniera ci avrei provato ad modificare .se riuscite fare qualcosa voi . vi ringrazio O_/
vi allego il sorgente
Codice: Seleziona tutto
;    8 Channel PWM LED Chaser for PIC 16F628/A                        *
;    Filename:                  pro481v207.asm                        *
;    Date:                      27/10/2010                            *
;    File Version:              2.0.7                                 *
;    Author:                    Pete Griffiths                        *
;    Company:                   http://picprojects.org.uk             *
;    Written and assmbled under MPLAB Version 8.20                    *
;    Before assembling code set correct PIC processor in MPLAB        *
;    from menu option Configure - Select Device                       *
;    Now works with 16F84A, 16F627/628 16F627A/628A and 16F88         *
;    The devices with 1K program memory (16F84A, 16F627/627A          *
;    will need some Sequences in pwmc_SeqData.inc file removing       *
;    to fit the code in their limited memory.                         *
;    27/10/2010                                                       *
;    PWM LED Chaser variant code for use with PCB480C only            *
;    Notes:                                                           *
;     1. PIC 16F628A datasheet can be downloaded from                 *
;        http://ww1.microchip.com/downloads/en/DeviceDoc/40044b.pdf   *
;     2. See also MPASM User Guide(UG) which can be downloaded from:  *
;        http://ww1.microchip.com/downloads/en/DeviceDoc/33014J.pdf   *
;        http://picprojects.org.uk/projects/ledchaser/                *
;     3. This code uses Pseudo-instructions listed in the MPASM User  *
;        guide, Part 4, Appendix A.5                                  *
;     4. For list of Radix types see MPASM UG Section 3.4, Table 3-3  *
   ifdef __16F88
   #include <p16f88.inc>
      ;Program Configuration Register 1
      __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_ON & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
      ;Program Configuration Register 2
      __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
   #define T0IF   TMR0IF
   #define T0IE   TMR0IE
   endif
              ifdef __16F628A
               #include <p16f628A.inc>      ; Standard include file
                                            ; defines processor specific variable definitions
                                            ; See MPASM UG Section 4.41
              ; '__CONFIG' directive is used to embed configuration data within .asm file.
              ; The lables following the directive are located in the respective .inc file.
              ; See respective data sheet for additional information on configuration word.
              ; and also see MPASM UG Section 4.12
               __CONFIG   _CP_OFF & _WDT_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF
              endif
              ifdef __16F628
               #include <p16f628.inc>
              endif
              ifdef __16F84A
   ; **** 16F84A only has 1K of program memory - the default pwm_SeqData.inc file ****
   ; **** will not fit into the available memory, you must remove some of the     ****
   ; **** the sequence data from the file before assembling the code              ****
               #include <p16f84a.inc>
                __CONFIG   _CP_OFF & _WDT_ON & _PWRTE_ON & _HS_OSC
              ; Code protect off
              ; Watch Dog timer off
              ; Power-up timer delay on
              ;   change to _RC_OSC for resistor/capacitor
              ;   change to _XT_OSC for crystal/resonator <3.5Mhz
              ;   change to _HS_OSC for high speed crystal/resonator >3.5Mhz
              endif
              ; Suppress specific warning messages
              ; see MPASM UG Section 4.29 for errorlevel directive
              ; see MPASM UG Section 8.4 for assembler message descriptions
              errorlevel -302     ; suppress banksel warning messages during assembly
              ; define variables in General Purpose Register (GPR) memory
              ; See MPASM UG Section 4.8
              ; note: 16F84A GPR start at 0x0C but most other mid-range PICs start at 0x20
              ; We use 0x20 here for compatibilty with newer PICs
              cblock 0x20
                firstGPR:0                ; mark start of GPR memory used
                state                     ; used by function state selector
                copyPORTB                 ; working variable, holds copy of PORTB
                vc0,vc1,vc2,vc3,vc4       ; vertical counter bits
                hiReload                  ; vertical counter reload hi
                loReload                  ; vertical counter reload lo
                PWM                       ; PWM counter
                holdTime                  ; sequence line hold time
                repeatCount               ; repeat seqeunce count
                RandMask                  ; mask to AND random number with
                seqIdxLo                  ; Lo byte address index pointer to start of selected sequence
                seqIdxHi                  ; Hi byte address index pointer to start of selected sequence
                seqTotal                  ; Total number of sequences in data
                seqMatch                  ; working variable
                seqCount                  ; working variable
                forward                   ; working regsiter for mirroring data
                reverse                   ; working regsiter for mirroring data
                reloadTemp                ; temporary holding variable for loReload
                tick                      ; timer0 ticks
                swTimer                   ; switch hold down timer
                flags                     ; function flags register
     mode      ; mode flags register
                indexLo                   ; Lo byte sequence line data address pointer
                indexHi                   ; Hi byte sequence line data address pointer
                save_W                    ; save W during interupt
                save_Status               ; save STATUS during interupt
                save_PCLATH               ; save PCLATH
     saveModeTimerL   ; holdoff timer for saving opmode to EEPROM high
     saveModeTimerH   ; holdoff timer for saving opmode to EEPROM low
     eesave_W      ; temp register used in EEPROM routings
                LFSRH                     ; Random number shift regsiter high byte
                LFSRL:0                   ; Random number shift register low byte
                lastGPR                   ; mark last GPR register used
                                          ; (required by GPR initialisation code)
              endc
; EEPROM data
;    ; program parameters
   org 0x2100
   de .0
   de .1
   de .0
   ; embed firmware release info
   de " PRO481 PWM LED Chaser "
   de " V2.0.7 "
   de " 27/10/2010 "
   de " picprojects.org.uk "
; Define bank select pseudo instructions to make code more readable
#define   bank0     bcf       STATUS,RP0          ; Sel Bank 0
#define   bank1     bsf       STATUS,RP0          ; Sel Bank 1
; See MPASM UG Secdtion 4.27 for definition of equ directive
switch        equ 4         ; Port bit switch connected to
cSAVETIME EQU     d'4'   ; holdoff timer constant for saving EEPROM data
cTIMER    EQU   d'157'
cTICKS    EQU   d'50'
; 4Mhz oscillator clock, gives TMR0 clock = 1Mhz.
; Write to timer0 inhibits clock for 2 clock cycles
; TMR0 prescaler of 1:2 gives
; 1Mhz / ((256-157+2) x 2) = 5Khz = 0.2mS
; 50 x 0.2mS = 10mS
; So the sequence hold time will be 10mS x holdTime, giving a range of
; 1 = 10mS thru 254 = 2.54S
; remember that a holdtime value of 255 indicates the end of the sequence so DON'T USE IT
; define flag bits
fHoldTimeout  EQU           0             ; flag set by ISR, cleared by Table Lookup function
fSwitch       EQU           1             ; flag
fsetupRun     EQU           2             ; 0=run mode / 1=setup mode
fTick         EQU           3             ; timer tick flag
fSaveMode   EQU   4   ; set indicates opmode needs writing to EEPROM, clear indicates no data to write
;      5
fMirrorData   EQU           6             ; flag set, Table read reverses bits in data word [** This flag must be Bit 6 **]
fMirrorNext   EQU           7             ; flag tells code current sequence should be mirrored next time
#define   canMirror 1<<fMirrorData        ; Don't change the position of this bit, sequence data expects it here
; define mode bits
modeSeq   EQU   0
modeRan   EQU   1
modeMan   EQU   2
modeSleep   EQU   3
; Program code starts here
; See MPASM UG Section 1.7.1, and Example 1-1
; Labels      Mnemonics     Operands                     Comments
;             Directives
;             Macros
RESET_VECTOR  org           0x000                       ; see MPASM UG Section 4.50
              goto          START                       ; START label is in pwmc_start.inc
INTERRUPT_V   org           0x004                       ; Interrupt handler code must follow this origin statement
              #include pro481_inth.inc                    ; include Interrupt Handler code block
              #include pro481_statef.inc                  ; include main state function code block (must reside in page 0)
              #include pro481_start.inc                   ; include reset and initialisation code
              #include pro481_functions.inc             ; include all program functions
              #include pro481_SeqMacro.inc                ; include MACRO definitions for sequence data
                                                        ; used for creating sequence data tables
; DO NOT CHANGE OR REMOVE this label
SeqBaseAddr   ; label marks base address for start of sequence data.
              ; Include your sequence data file(s) here
   #include pro481_SeqData.inc                 ; file containg sequence data
   ;#include pro481_xmastree.inc               ; alternate data for use with xmas tree PCB
              ; Do not remove this instruction
_markLast     retlw         .255          ; Ensure last sequence is marked
              end           ; end of instructions, always needed
Foto Utentesteorai
30 5
[2] Re: modifica firmware
Messaggioda Foto UtenteIlGuru » 14 dic 2017, 20:29
Per 500€ possiamo parlarne
Foto UtenteIlGuru
5.482 2 10 13
[3] Re: modifica firmware
Messaggioda Foto Utentesteorai » 15 dic 2017, 0:25
Per una birra?
Foto Utentesteorai
30 5
[4] Re: modifica firmware
Messaggioda Foto UtenteIlGuru » 15 dic 2017, 14:42
Suggerimento:
In quel listato non c'è il codice che vorresti modificare.
Foto UtenteIlGuru
5.482 2 10 13
[5] Re: modifica firmware
Messaggioda Foto Utentesteorai » 15 dic 2017, 15:55
allora non ho speranza . nell'archivio che ho scaricato dal sito ci sono altri file ma non so che cosa siano
Foto Utentesteorai
30 5
[6] Re: modifica firmware
Messaggioda Foto Utentespeedyant » 15 dic 2017, 16:08
Gli altri file sono inerenti il "sistema di sviluppo"
Quale versione di mplab hai?
5.093 3 6 8
[7] Re: modifica firmware
Messaggioda Foto Utentesteorai » 15 dic 2017, 16:41
non la ho ancora scaricata mplab stavo guardando con l'editor di testo se trovavo la scritta DelayMS per aumentare il tempo
Foto Utentesteorai
30 5
