<prev>
- SCRAMBLER DIGITALE
- 041015
- RC0 = DATA INPUT
- RC1 = LED
- RC2 = OUT B.F.
- RC3 = ING. B.F.
- RC4 = PULSANTE INC.
- RC5 = PULSANTE DEC.
- RA0 = n.c.
- RA1 = V.REF ADC
- RA2 = C.S.
- RA3 = n.c.
- RA4 = DATA OUT
- RA5 = CLOCK
PROCESSOR 16F1704 RADIX DEC INCLUDE "P16F1704.INC"
ERRORLEVEL -302 ERRORLEVEL -305
ORG 0170H ; 130H
INDL RES 1 INDH RES 1 LINEA RES 1 DATO_LEG RES 1 DATO_SCRI RES 1 RIT RES 2 CONTA RES 1 DIREZ RES 1 PASSATA RES 1 CONT_BIT RES 1 TEMP_L RES 1 TEMP_H RES 1
__CONFIG H'8007', H'3FA4' __CONFIG H'8008', H'1FFF'
ORG 00H
VIA
MOVLB 1 MOVLW B'00000011' MOVWF TRISA
MOVLB 0 MOVLW B'00000010' MOVWF PORTC
- MOVLB 2
- CLRF LATC
MOVLW B'00000100' MOVWF LATA
MOVLB 3 CLRF ANSELC
MOVLB 2 MOVLW B'10000000' MOVWF DAC1CON0
MOVLB 10 MOVLW B'10010010' MOVWF OPA1CON
MOVLB 1 MOVLW B'00011101' MOVWF ADCON0
MOVLW B'01100010' MOVWF ADCON1
MOVLW B'00000000' MOVWF ADCON2
MOVLW B'00111001' MOVWF TRISC
MOVLW B'11110000' ;26mS MOVWF OSCCON
BCF OPTION_REG,7 ;pull-up
MOVLB 3 MOVLW B'00001000' ;MOVLW B'00010000' MOVWF ANSELC ;MOVWF ANSELA
- INIZIALIZZO SPI
MOVLB .29 MOVLW .18 ;SDO SU RC3 MOVWF RA4PPS ; ERA RC4PPS ;ERA SU RC3 MOVLW .16 ;SCK MOVWF RA5PPS ;ERA RC4PPS
MOVLB .28 MOVLW .16 ;SDI SU RC0 MOVWF SSPDATPPS
MOVLB .4 MOVLW .1 MOVWF SSP1ADD MOVLW B'00001010' MOVWF SSP1CON1 MOVLW B'11000000' MOVWF SSP1STAT BSF SSP1CON1, 5
MOVLW .255 MOVWF LINEA CLRF INDH CLRF INDL CLRF DIREZ CLRF RIT+0 CLRF RIT+1 CLRF CONTA MOVLW .3 MOVWF PASSATA
CICLO
- ---avvio nuova ADC----
MOVLB 1 BSF ADCON0,ADGO
- --avviato--
- -----leggo un byte dalla ram-------
RILEGGI
MOVLB 0 ; n° del banco BCF LATA,2 ; C.S. NOP MOVLB .4 ; n° del banco
MOVLW .03 ; comando in lettura MOVWF SSP1BUF
ANCORA1L
BTFSS SSP1STAT, 0 GOTO ANCORA1L
MOVFW INDH ; indirizzo alto MOVWF SSP1BUF
ANCORA2L
BTFSS SSP1STAT, 0 GOTO ANCORA2L
MOVFW INDL ; indirizzo basso MOVWF SSP1BUF
ANCORA3L
BTFSS SSP1STAT, 0 GOTO ANCORA3L
MOVLW .255 ; finto dato in uscita MOVWF SSP1BUF
ANCORA4L ;leggo dato in arrivo
BTFSS SSP1STAT, 0 GOTO ANCORA4L
MOVFW SSP1BUF
- MOVWF DATO_LEG ;salvo dato letto
MOVLB 0 ; n° del banco BSF LATA,2 ; C.S. NOP
- ---fine lettura----
- -----scrivo un byte nell' DAC----------
- MOVFW DATO_LEG
MOVLB 2 MOVWF DAC1CON1
- ----fine----
- -----scrivo un byte nella ram----------
RIPETI
MOVLB .4 ; n° del banco MOVLW .02 ; comando in scrittura MOVWF SSP1BUF
ANCORA1
ANCORA2
ANCORA3
MOVFW DATO_SCRI ; dato da scrivere MOVWF SSP1BUF
ANCORA4
- ----fine scrittura------
MOVLB 1 ;conversione ADC terminata ?
NON_PRONTO
BTFSC ADCON0,ADGO GOTO NON_PRONTO
MOVFW ADRESH MOVWF DATO_SCRI
- --controllo dec/cod----
MOVLB 0 BTFSS PORTC,5 GOTO PUNTATORE
- ----decodifica tono---------
DEC_TONO
BTFSS DATO_SCRI,7 GOTO MIN_127
- MAG_127 ---semionda alta---
INCF TEMP_H BTFSS PASSATA,0 GOTO FINE_CTRL_BIT BCF PASSATA,0 BSF PASSATA,1 MOVFW TEMP_L ADDLW 256-13 ; è <= DI 10 ?? BTFSC STATUS,C GOTO MAG_7L
- MIN_7
CLRF TEMP_L INCF CONT_BIT GOTO FINE_MISURA
MAG_7L
CLRF CONT_BIT CLRF TEMP_L GOTO FINE_CTRL_BIT
MIN_127 ;---semionda bassa---
INCF TEMP_L BTFSS PASSATA,1 GOTO FINE_CTRL_BIT BCF PASSATA,1 BSF PASSATA,0 MOVFW TEMP_H ADDLW 256-13 ; è <= DI 10 ?? BTFSC STATUS,C GOTO MAG_7H
- MIN_7
CLRF TEMP_H INCF CONT_BIT GOTO FINE_MISURA
MAG_7H
CLRF CONT_BIT CLRF TEMP_H GOTO FINE_CTRL_BIT
FINE_MISURA ;semionde in arrivo
MOVFW CONT_BIT ADDLW 256-20 ; è > 20 ?? BTFSS STATUS,C GOTO FINE_CTRL_BIT CLRF CONT_BIT CLRF INDH CLRF INDL CLRF DIREZ
FINE_CTRL_BIT
- ---puntatore memoria----
PUNTATORE
BTFSC DIREZ,0 GOTO INVERSO
INCFSZ INDL GOTO CICLO INCFSZ INDH GOTO CICLO
DECF INDL ;carico FF DECF INDH ;carico FF BSF DIREZ,0 GOTO CICLO
INVERSO
DECF INDL COMF INDL,W ; =FF ? BTFSS STATUS,Z GOTO CICLO DECF INDH COMF INDH,W ; =FF ? BTFSS STATUS,Z GOTO CICLO
BCF DIREZ,0 CLRF INDL CLRF INDH
MOVLB 0 BTFSC PORTC,5 GOTO CICLO
SINCRO
CLRF CONTA MOVLB 2
SINCRO1
MOVLW .255 ; semip+ MOVWF DAC1CON1 MOVLW .3 MOVWF RIT+1
NO_ZERO1
DECFSZ RIT+0 GOTO NO_ZERO1 DECFSZ RIT+1 GOTO NO_ZERO1
MOVLW .0 ; semip- MOVWF DAC1CON1 MOVLW .3 MOVWF RIT+1
NO_ZERO2
DECFSZ RIT+0 GOTO NO_ZERO2 DECFSZ RIT+1 GOTO NO_ZERO2
INCF CONTA BTFSS CONTA,4 GOTO SINCRO1 GOTO CICLO
END
</prev>
