salve,
Ho un motore in cc, controllato tramite scheda dspace che si interfaccia con matlab simulink.Posso controllare il motore in cc tramite linee di comando nel workspace di matlab.Ora il mio quesito è il seguente: come posso inviare line di comando da un PC ad un altro e viceversa tramite matlab???
utilizzare matlab in remoto
4 messaggi
Ho trovato su internet due funzioni matlab una per il server, e l'altra per il client
% SERVER Write a message over the specified port
% Usage - server(message, output_port, number_of_retries)
function server(message, output_port, number_of_retries)
import java.net.ServerSocket
import java.io.*
if (nargin < 3)
number_of_retries = 20; % set to -1 for infinite
end
retry = 0;
server_socket = [];
output_socket = [];
while true
retry = retry + 1;
try
if ((number_of_retries > 0) && (retry > number_of_retries))
fprintf(1, 'Too many retries\n');
break;
end
fprintf(1, ['Try %d waiting for client to connect to this ' ...
'host on port : %d\n'], retry, output_port);
% wait for 1 second for client to connect server socket
server_socket = ServerSocket(output_port);
server_socket.setSoTimeout(1000);
output_socket = server_socket.accept;
fprintf(1, 'Client connected\n');
output_stream = output_socket.getOutputStream;
d_output_stream = DataOutputStream(output_stream);
% output the data over the DataOutputStream
% Convert to stream of bytes
fprintf(1, 'Writing %d bytes\n', length(message))
d_output_stream.writeBytes(char(message));
d_output_stream.flush;
% clean up
server_socket.close;
output_socket.close;
break;
catch
if ~isempty(server_socket)
server_socket.close
end
if ~isempty(output_socket)
output_socket.close
end
% pause before retrying
pause(1);
end
end
end
% CLIENT connect to a server and read a message
% Usage - message = client(host, port, number_of_retries)
function message = client(host, port, number_of_retries)
import java.net.Socket
import java.io.*
if (nargin < 3)
end
retry = 0;
input_socket = [];
message = [];
while true
retry = retry + 1;
break;
end
try
fprintf(1, 'Retry %d connecting to %s:%d\n', ...
retry, host, port);
% throws if unable to connect
input_socket = Socket(host, port);
% get a buffered data input stream from the socket
input_stream = input_socket.getInputStream;
d_input_stream = DataInputStream(input_stream);
fprintf(1, 'Connected to server\n');
% read data from the socket - wait a short time first
pause(0.5);
bytes_available = input_stream.available;
fprintf(1, 'Reading %d bytes\n', bytes_available);
message = zeros(1, bytes_available, 'uint8');
for i = 1:bytes_available
message(i) = d_input_stream.readByte;
end
message = char(message);
% cleanup
input_socket.close;
break;
catch
if ~isempty(input_socket)
input_socket.close;
end
pause(1);
end
end
end
Vorrei chiedervi gentilmente, se posso testare contemporaneamente queste due funzioni, per vedere se funzionano.Leggendo la guida matlab dopo aver digitato tcpip ho trovato echotcpip che mi dice come testare un una richiesta remota virtuale.
import java.io.*
if (nargin < 3)
end
retry = 0;
server_socket = [];
output_socket = [];
while true
retry = retry + 1;
try
break;
end
% clean up
break;
catch
server_socket.close
end
output_socket.close
end
pause(1);
end
end
end
import java.io.*
if (nargin < 3)
end
retry = 0;
input_socket = [];
message = [];
while true
retry = retry + 1;
break;
end
try
retry, host, port);
pause(0.5);
end
% cleanup
input_socket.close;
break;
catch
input_socket.close;
end
pause(1);
end
end
end
4 messaggi
