Joel Spolsky ha scritto:One good way to evaluate the usability of a program or dialog you've never seen before is to act a little stupid. Don't read the words on the dialog. Make random assumptions about what things do without verifying. Try to use the mouse with just one finger. Make lots of mistakes, and generally thrash around. See if the program does what you want, or at least, gently guides you instead of blowing up. Be impatient. If you can't do what you want right away, give up. If the UI can't withstand your acting generally immature and stupid, it could use some work.
