Problema con montaggio di un gruppo di unita' LVM
Linguaggi e sistemi
[51] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealev » 26 ott 2011, 21:21
Allora, riproviamo con i comandi di prima, voglio sincerarmi che non ci siano più problemi hardware:
Codice: Seleziona tutto
lvremove --noudevsync /dev/mapper/home-home
vgremove --noudevsync -f home
Foto Utentealev
5.995 2 9 12
[52] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealien75 » 26 ott 2011, 22:50
root@server:~# fdisk -l
Disk /dev/sda: 82.0 GB, 81964302336 bytes
255 heads, 63 sectors/track, 9964 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x7461bf6e
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1        9965    80040961    5  Extended
/dev/sda5               1        1531    12288000   83  Linux
/dev/sda6            1531        1624      747520   82  Linux swap / Solaris
/dev/sda7            6488        9965    27929600   8e  Linux LVM
/dev/sda8            1624        6488    39067648   83  Linux
Partition table entries are not in disk order
Disk /dev/sdb: 82.0 GB, 81964302336 bytes
Disk identifier: 0x0002b9be
/dev/sdb1               1        9964    80035798+  8e  Linux LVM
Disk /dev/sdc: 300.1 GB, 300069052416 bytes
255 heads, 63 sectors/track, 36481 cylinders
Disk identifier: 0x00072e18
/dev/sdc1               1       36482   293033985    5  Extended
/dev/sdc5               1       36482   293033984   8e  Linux LVM
Disk /dev/sde: 300.1 GB, 300069052416 bytes
Disk identifier: 0xc860c860
/dev/sde1               1       36482   293033985    5  Extended
/dev/sde5               1       36482   293033984   8e  Linux LVM
Disk /dev/sdd: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Disk identifier: 0x0001412b
/dev/sdd1               1       38914   312568833    5  Extended
/dev/sdd5               1       38914   312568832   8e  Linux LVM
Disk /dev/sdf: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x000ccf43
/dev/sdf1               1       60802   488385536   8e  Linux LVM
root@server:~# lvremove --noudevsync /dev/mapper/home-home
  One or more specified logical volume(s) not found.
Ti riporto il risultato di #fdisk -l e degli altri due comandi:
root@server:~#
root@server:~# clear
root@server:~# vgremove --noudevsync -f home
  Cannot change VG home while PVs are missing!
scusami se mi sono assentato per un' ora ma dopo aver sistemato il SATA non ho piu' visto gli altri disconi da 300 quindi ho dovuto spegnere per sistemare il problema: l'hardware ha comportamenti imprevedibili e senza senso.
Foto Utentealien75
1 1 4 7
[53] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealev » 27 ott 2011, 9:50
alien75 ha scritto:l'hardware ha comportamenti imprevedibili e senza senso.
Concordo, l'avevo già immaginato da tempo ma tu me lo confermi.
Secondo me, è opportuno stabilizzare le condizioni dell'hardware perché se non garantisce affidabilità è inutile perderci tempo, IMHO.
Foto Utentealev
5.995 2 9 12
[54] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealien75 » 27 ott 2011, 13:28
Mi e' venuta un' idea: ho constatato che i vari volumi fisici vengono sempre visti
avviando il CD dell' installazione i volumi fisici vengono sempre visti tutti senza problemi.
Propongo quindi di togliere il vari volumi logici lvm dal gruppo, sotto il CD di installazione con
l'apposito software ncourses che c'e' li sotto. Noto infatti che riesco a toglire o modificare il tutto senza problemi con il CD dell' installazione.
Ora il problema di ieri si e' risolto e le condizioni appaiono abbastanza stabili: quindi
se tu mi dai il permesso di farlo e se si puo' fare toglierei il gruppo con tutti i suoi volumi lvm
dal CD dell' installalzione di ubuntu.
Che ne dici?
Foto Utentealien75
1 1 4 7
[55] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealev » 27 ott 2011, 14:21
alien75 ha scritto:Ora il problema di ieri si e' risolto e le condizioni appaiono abbastanza stabili: quindi
E' la parola abbastanza che mi preoccupa, di solito si usa per una quantità relativa ma lontana dall'assoluto; l'affidabilità dell'hardware di un computer deve essere molto elevata e tale da garantire l'assenza di impicci e rotture di scatole almeno durante l'installazione e l'utilizzo per qualche tempo, cosa che in questo caso non è stata.
Inoltre, non sono certo io che concedo il permesso ad alcuno di fare o non fare una determinata azione, nei limiti del rispetto reciproco; come si dice, sei maggiorenne e vaccinato, hai tutto il diritto di prendere le decisioni che ti riguardano, compresa questa.
Quello che posso dirti, a questo punto, visto che sul server non c'è ancora nulla, tanto vale reinstallare tutto daccapo (ma la decisione devi prenderla tu), con i seguenti accorgimenti:
1. Non creare partizioni logiche se non ti serve avere più di 4 partizioni in totale in un disco
2. Le partizioni che devi accorpare per formare il volume-group devono essere di tipo "Linux raid autodetect" (codice fd)
3. Per accorpare le partizioni di tipo "Linux raid autodetect" e formare un unico volume, devi creare un RAID 0 che "unisce" tra loro le partizioni di tipo "Linux raid autodetect".
4. Sul volumone così ottenuto, che deve essere di tipo LVM, dovrai creare il volume-group
5. Sul volume-group dovrai creare il logical-volume
6. Per montare il logical-volume, lo stesso deve essere formattato con mkfs.ext3
Foto Utentealev
5.995 2 9 12
[56] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealien75 » 27 ott 2011, 15:13
Sto' leggendo le differenze tra RAID0, RAID4 e RAID5: nel caso del RAID0 ho le prestazioni piu' elevate solo nel caso che si abbia tutti dischi di uguale capacita', cosa che nel mio caso non c'e'
dato che ho dischi delle piu' disparate dimensioni. Il limite del RAID0 e' che non c'e' la ridondanza
dei dati che mi da il RAID5, quindi se si rompe un' unita' i dati che vengono messi nel volume successivo coprendo i buchi mancanti.
Nel mio caso devo creare un server multimediale con mediatomb, quindi il volumone deve essere veloce, capiente per tutti i suoi 1,40Gb, ed al tempo stesso vorrei che in caso di rottura di una
unita' si possano recuperare i dati.
Che tipo di RAID sarebbe piu' adatto al caso? Il RAID0 e' prestante ma non utilizza la ridondanza
dei dischi, esso utilizza un altro sistema di salvataggio dei dati in caso di rottura si un disco facendomi utilizzare tutti i miei 1,40Gb.
Foto Utentealien75
1 1 4 7
[57] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealien75 » 27 ott 2011, 16:29
Leggendo in giro nel web vedo che nel mio caso sarebbe piu' adatti il RAID5 dato che mi permette
di avere C × (N − 1) di spazio utilizzabile ma almeno da la possibilita' di avere un disco rotto
non perdendone i dati, contro il C x N del RAID0 non da la possibilita' di avere dischi rotti.
Che pensi?
Foto Utentealien75
1 1 4 7
[58] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealev » 27 ott 2011, 16:34
Le migliori prestazioni con ridondanza si ottengono con il RAID 1 (che è un mirror tra i dischi); anche il RAID 5 ha buone prestazioni con la ridondanza ma richiede almeno 3 dischi e la capacità totale (somma dei dischi) va ridotta di 1/3.
Sia il RAID 1 che il 5 richiedono dischi di uguale capacità, diversamente equivale a mettere insieme dischi uguali aventi la capacitò del più piccolo.
Con i dischi che hai tu, non si riesce a fare 1,4 Gb con ridondanza e prestazioni.
Personalmente, acquisterei una coppia di dischi nuovi (sconsiglio i Maxtor) da 1,5 Tb e farei un RAID 1.
Con i dischi che hai tu, a spanne, puoi arrivare al massimo a 600 Gb con RAID 5.
Foto Utentealev
5.995 2 9 12
[59] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utentealien75 » 27 ott 2011, 16:43
alev ha scritto:Le migliori prestazioni con ridondanza si ottengono con il RAID 1 (che è un mirror tra i dischi); anche il RAID 5 ha buone prestazioni con la ridondanza ma richiede almeno 3 dischi e la capacità totale (somma dei dischi) va ridotta di 1/3.
Quindi nel caso io adotti RAID1 con i dischi che ho a disposizione avrei prestazioni, utilizzo totale dei miei 1,4Gb ma in casi uno si rompa da quello che leggo in giro vedo che ci sono comunque software che permettono di recuperarei dati dal disco rotto? Giusto o sbaglio?
Dato il mio caso e non voler piu' spendere per comprare nuovi dischi e quello che mi hai appena detto mi tengo quelli che ho ed opto quindi per il RAID0 pero' in caso di recupero dei dati non saranno copleti ma parzialmente incompleti.
Quindi la mia domanda e': ci sono programmi per linux che permettono di recuperare i dati
da un disco con filesystem rovinato oppure proprio rotto in un gruppo in RAID0?
Foto Utentealien75
1 1 4 7
[60] Re: Problema con montaggio di un gruppo di unita' LVM
Messaggioda Foto Utenteangus » 27 ott 2011, 17:38
RAID0... 6 dischi... LVM sopra...
stai per entrare in una valle di lacrime.
Se il tuo scopo non è puramente "accademico" ti consiglio di domandarti se davvero hai bisogno di quello che stai cercando di fare.
Foto Utenteangus
8.480 4 6 9
Torna a PC e informatica
