- Codice: Seleziona tutto
lvremove --noudevsync /dev/mapper/home-home
vgremove --noudevsync -f home
Paolino,
fairyvilje
lvremove --noudevsync /dev/mapper/home-homevgremove --noudevsync -f homeroot@server:~# fdisk -l
Disk /dev/sda: 82.0 GB, 81964302336 bytes
255 heads, 63 sectors/track, 9964 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x7461bf6e
Device Boot Start End Blocks Id System
/dev/sda1 * 1 9965 80040961 5 Extended
/dev/sda5 1 1531 12288000 83 Linux
/dev/sda6 1531 1624 747520 82 Linux swap / Solaris
/dev/sda7 6488 9965 27929600 8e Linux LVM
/dev/sda8 1624 6488 39067648 83 Linux
Partition table entries are not in disk order
Disk /dev/sdb: 82.0 GB, 81964302336 bytes
Disk identifier: 0x0002b9be
/dev/sdb1 1 9964 80035798+ 8e Linux LVM
Disk /dev/sdc: 300.1 GB, 300069052416 bytes
255 heads, 63 sectors/track, 36481 cylinders
Disk identifier: 0x00072e18
/dev/sdc1 1 36482 293033985 5 Extended
/dev/sdc5 1 36482 293033984 8e Linux LVM
Disk /dev/sde: 300.1 GB, 300069052416 bytes
Disk identifier: 0xc860c860
/dev/sde1 1 36482 293033985 5 Extended
/dev/sde5 1 36482 293033984 8e Linux LVM
Disk /dev/sdd: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Disk identifier: 0x0001412b
/dev/sdd1 1 38914 312568833 5 Extended
/dev/sdd5 1 38914 312568832 8e Linux LVM
Disk /dev/sdf: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x000ccf43
/dev/sdf1 1 60802 488385536 8e Linux LVM
root@server:~# lvremove --noudevsync /dev/mapper/home-home
One or more specified logical volume(s) not found.
root@server:~#
root@server:~# clear
root@server:~# vgremove --noudevsync -f home
Cannot change VG home while PVs are missing!
alien75 ha scritto:l'hardware ha comportamenti imprevedibili e senza senso.
alien75 ha scritto:Ora il problema di ieri si e' risolto e le condizioni appaiono abbastanza stabili: quindi
se tu mi dai il permesso di farlo e se si puo' fare toglierei il gruppo con tutti i suoi volumi lvm
dal CD dell' installalzione di ubuntu.
alev ha scritto:Le migliori prestazioni con ridondanza si ottengono con il RAID 1 (che è un mirror tra i dischi); anche il RAID 5 ha buone prestazioni con la ridondanza ma richiede almeno 3 dischi e la capacità totale (somma dei dischi) va ridotta di 1/3.
Sia il RAID 1 che il 5 richiedono dischi di uguale capacità, diversamente equivale a mettere insieme dischi uguali aventi la capacitò del più piccolo.
Con i dischi che hai tu, non si riesce a fare 1,4 Gb con ridondanza e prestazioni.
Personalmente, acquisterei una coppia di dischi nuovi (sconsiglio i Maxtor) da 1,5 Tb e farei un RAID 1.
Con i dischi che hai tu, a spanne, puoi arrivare al massimo a 600 Gb con RAID 5.
