Ho questo limite qui:
![\lim_{x\rightarrow +\infty}\sqrt[3]{x^3+2x^2}-x+1 \lim_{x\rightarrow +\infty}\sqrt[3]{x^3+2x^2}-x+1](/forum/latexrender/pictures/d3802c0f5eb485770f04acbb47365532.png)
dove l'argomento l'ho risolto così:
![\sqrt[3]{x^3+2x^2}-(x-1)\cdot\frac{\sqrt[3]{(x^3+2x^2)^2}+(x-1)\sqrt[3]{x^3+2x^2}+(x-1)^2}{\sqrt[3]{(x^3+2x^2)^2}+(x-1)\sqrt[3]{x^3+2x^2}+(x-1)^2}= \sqrt[3]{x^3+2x^2}-(x-1)\cdot\frac{\sqrt[3]{(x^3+2x^2)^2}+(x-1)\sqrt[3]{x^3+2x^2}+(x-1)^2}{\sqrt[3]{(x^3+2x^2)^2}+(x-1)\sqrt[3]{x^3+2x^2}+(x-1)^2}=](/forum/latexrender/pictures/bf968bb248e5c385d31e6b6cc4ae5fe9.png)
![\tfrac{x^3+2x^2+(x-1)\sqrt[3]{(x^3+2x^2)^2}+(x-1)^2\sqrt[3]{x^3+2x^2}-(x-1)\sqrt[3]{(x^3+2x^2)^2}-(x-1)^2\sqrt[3]{x^3+2x^2}-(x-1)^3}{\sqrt[3]{[x^3(1+\frac{2}{x})]^2}+(x-1)\sqrt[3]{x^3(1+\frac{2}{x})}+x^2-2x+1}= \tfrac{x^3+2x^2+(x-1)\sqrt[3]{(x^3+2x^2)^2}+(x-1)^2\sqrt[3]{x^3+2x^2}-(x-1)\sqrt[3]{(x^3+2x^2)^2}-(x-1)^2\sqrt[3]{x^3+2x^2}-(x-1)^3}{\sqrt[3]{[x^3(1+\frac{2}{x})]^2}+(x-1)\sqrt[3]{x^3(1+\frac{2}{x})}+x^2-2x+1}=](/forum/latexrender/pictures/38d93c9782d8c9d4d516d33a7e5a18b1.png)
![\frac{5x^2-3x+1}{x^2\sqrt[3]{(1+\frac{2}{x})^2}+x^2\sqrt[3]{1+\frac{2}{x}}-x\sqrt[3]{1+\frac{2}{x}}+x^2-2x+1} \frac{5x^2-3x+1}{x^2\sqrt[3]{(1+\frac{2}{x})^2}+x^2\sqrt[3]{1+\frac{2}{x}}-x\sqrt[3]{1+\frac{2}{x}}+x^2-2x+1}](/forum/latexrender/pictures/b91c2390217c9e3a6fd0483f08bb4be3.png)
![\frac{x^2(5-\frac{3}{x}+\frac{1}{x^2})}{x^2(\sqrt[3]{(1+\frac{2}{x})^2}+\sqrt[3]{1+\frac{2}{x}}-\frac{\sqrt[3]{1+\frac{2}{x}}}{x}+1-\frac{2}{x}+\frac{1}{x})} \frac{x^2(5-\frac{3}{x}+\frac{1}{x^2})}{x^2(\sqrt[3]{(1+\frac{2}{x})^2}+\sqrt[3]{1+\frac{2}{x}}-\frac{\sqrt[3]{1+\frac{2}{x}}}{x}+1-\frac{2}{x}+\frac{1}{x})}](/forum/latexrender/pictures/42c1b25cecc81f8f3f1ca4f00d1115fd.png)
![\frac{5-\frac{3}{x}+\frac{1}{x^2}}{\sqrt[3]{(1+\frac{2}{x})^2}+\sqrt[3]{1+\frac{2}{x}}-\frac{\sqrt[3]{1+\frac{2}{x}}}{x}+1-\frac{2}{x}+\frac{1}{x}} \frac{5-\frac{3}{x}+\frac{1}{x^2}}{\sqrt[3]{(1+\frac{2}{x})^2}+\sqrt[3]{1+\frac{2}{x}}-\frac{\sqrt[3]{1+\frac{2}{x}}}{x}+1-\frac{2}{x}+\frac{1}{x}}](/forum/latexrender/pictures/f74b63f872637c7c2ebef58121125d02.png)
ed infine si ha che il limite risulta:
![\lim_{x\rightarrow +\infty}\frac{5-\frac{3}{x}+\frac{1}{x^2}}{\sqrt[3]{(1+\frac{2}{x})^2}+\sqrt[3]{1+\frac{2}{x}}-\frac{\sqrt[3]{1+\frac{2}{x}}}{x}+1-\frac{2}{x}+\frac{1}{x}}=\frac{5}{3} \lim_{x\rightarrow +\infty}\frac{5-\frac{3}{x}+\frac{1}{x^2}}{\sqrt[3]{(1+\frac{2}{x})^2}+\sqrt[3]{1+\frac{2}{x}}-\frac{\sqrt[3]{1+\frac{2}{x}}}{x}+1-\frac{2}{x}+\frac{1}{x}}=\frac{5}{3}](/forum/latexrender/pictures/1e48943944d1aed4ec7ba18998d554db.png)
Quello che mi domando è se, tralasciando eventuali teoremi, si poteva risolvere in un modo più semplice.
Ringrazio a chi avrà voglia di cimentarsi
PietroBaima,
Ianero
EcoTan ha scritto:(altrimenti verrebbe semplicemente =1)
; mentre se provo ad estrarre le x di ordine superiore come hai detto mi ritrovo sempre con una forma di indecisione ma del tipo
.EcoTan ha scritto:allora c'è una regola per sapere quando si può fare?
EcoTan ha scritto:non si direbbe subito che il risultato è 3/5 trascurando i termini di grado inferiore?
Sbaglio?
EcoTan ha scritto:Allora mi chiedevo se c'è una regola per accorgersi quando i termini di grado inferiore non si possono invece trascurare (più che altro allo scopo di evitare errori macroscopici)
PietroBaima ha scritto:
?![\sqrt[3]{(x-1)^3+5x^2-3x+1}-x+1 \sqrt[3]{(x-1)^3+5x^2-3x+1}-x+1](/forum/latexrender/pictures/b0b0cee1e20f4ca14cc1580d7fae3c28.png)
![\sqrt[3]{(x-1)^3\left (1+\frac{5x^2}{(x-1)^3}-\frac{3x}{(x-1)^3}+\frac{1}{(x-1)^3} \right )}-(x-1) \sqrt[3]{(x-1)^3\left (1+\frac{5x^2}{(x-1)^3}-\frac{3x}{(x-1)^3}+\frac{1}{(x-1)^3} \right )}-(x-1)](/forum/latexrender/pictures/b197ecc3885d2ceb6d3ccb70d83c2c98.png)
![(x-1)\sqrt[3]{1+\frac{5x^2}{x^3(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}-\frac{3x}{x^3(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}+\frac{1}{(x-1)^3}}-(x-1) (x-1)\sqrt[3]{1+\frac{5x^2}{x^3(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}-\frac{3x}{x^3(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}+\frac{1}{(x-1)^3}}-(x-1)](/forum/latexrender/pictures/a7a04e6db3bb58d9ae1aa1b2f37a02f5.png)
![(x-1)\left ( \sqrt[3]{1+\frac{5}{x(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}-\frac{3}{x^2(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}+\frac{1}{(x-1)^3}}-1 \right ) (x-1)\left ( \sqrt[3]{1+\frac{5}{x(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}-\frac{3}{x^2(1-\frac{3}{x}+\frac{3}{x^2}-\frac{1}{x^3})}+\frac{1}{(x-1)^3}}-1 \right )](/forum/latexrender/pictures/846355a31e731dacd2b4b111b2ebcf94.png)
wall87 ha scritto:Non so, forse ho sbagliato qualche cosa?
![\lim_{x\rightarrow +\infty}\sqrt[3]{x^3+2x^2}-x+1= \lim_{x\rightarrow +\infty}\sqrt[3]{x^3+2x^2}-x+1=](/forum/latexrender/pictures/bd2a7aea6b06d38b02b2c5af9ec68ef1.png)
![1+\lim_{x\rightarrow +\infty}\sqrt[3]{x^3+2x^2}-x= 1+\lim_{x\rightarrow +\infty}\sqrt[3]{x^3+2x^2}-x=](/forum/latexrender/pictures/f2008a7d096b6078ea9c53b996210b54.png)
![1+\lim_{x\rightarrow +\infty}x\left(\sqrt[3]{1+\frac{2}{x}}-1\right) 1+\lim_{x\rightarrow +\infty}x\left(\sqrt[3]{1+\frac{2}{x}}-1\right)](/forum/latexrender/pictures/e04a7bd8431fe8365261f8a4ae4197f8.png)
da cui
![1+\lim_{x\rightarrow +\infty}x \frac{1+\frac{2}{x}-1}{\left(1+\frac{2}{x}\right) ^\frac{2}{3}+\sqrt[3]{1+\frac{2}{x}}+1}=\frac{5}{3} 1+\lim_{x\rightarrow +\infty}x \frac{1+\frac{2}{x}-1}{\left(1+\frac{2}{x}\right) ^\frac{2}{3}+\sqrt[3]{1+\frac{2}{x}}+1}=\frac{5}{3}](/forum/latexrender/pictures/a5cdc0ea18957f0f009ff39e2e55a219.png)
![\left. \sqrt[n]{1+x} \right|_{x \rightarrow 0} = 1+\frac{x}{n}+\mathrm{o}[x^2] \left. \sqrt[n]{1+x} \right|_{x \rightarrow 0} = 1+\frac{x}{n}+\mathrm{o}[x^2]](/forum/latexrender/pictures/d0c5731c1fa4d885b419dfceffa3f63b.png)
