mi spiego...
io mi ritrovo con la corrente
, quindi sotto forma di numero complesso...il fasore associato alla sinusoide..poi scrivo
![\[I_{t_{2}}= I_{t_{1}}\cdot e^{-j\frac{2}{3}\pi} \] \[I_{t_{2}}= I_{t_{1}}\cdot e^{-j\frac{2}{3}\pi} \]](/forum/latexrender/pictures/53212a6bef3d9cba1084247d0b877ae0.png)
e
![\[I_{t_{3}}= I_{t_{1}}\cdot e^{+j\frac{2}{3}\pi} \] \[I_{t_{3}}= I_{t_{1}}\cdot e^{+j\frac{2}{3}\pi} \]](/forum/latexrender/pictures/1d0897bc362f90113547db5d3a3f2348.png)
dopodichè mi ricavo
![\[I_{12}= \frac{I_{t_{1}}}{\sqrt{3}}\cdot e^{+j\frac{\pi }{6}}\] \[I_{12}= \frac{I_{t_{1}}}{\sqrt{3}}\cdot e^{+j\frac{\pi }{6}}\]](/forum/latexrender/pictures/f3f98ef6a4a9b61142266bac5082fdc8.png)
![\[I_{23}= \frac{I_{t_{2}}}{\sqrt{3}}\cdot e^{+j\frac{\pi }{6}}\] \[I_{23}= \frac{I_{t_{2}}}{\sqrt{3}}\cdot e^{+j\frac{\pi }{6}}\]](/forum/latexrender/pictures/811bdd726f7eecbb716b2339b962d557.png)
![\[I_{31}= \frac{I_{t_{3}}}{\sqrt{3}}\cdot e^{+j\frac{\pi }{6}}\] \[I_{31}= \frac{I_{t_{3}}}{\sqrt{3}}\cdot e^{+j\frac{\pi }{6}}\]](/forum/latexrender/pictures/44ae9354dd3524ac78cd4e629770bc90.png)
ora dovendo scrivere le
e ![\[i_{31}(t)\] \[i_{31}(t)\]](/forum/latexrender/pictures/410db32708fb10527a6ada413ec2a207.png)
e volendo utilizzare la formula che ho scritto prima...
devo procedere così??
![\[i_{12}(t)=\sqrt{2}\cdot \frac{I_{t_{1}}}{\sqrt{3}}\cdot \sin \left ( \omega t+\varphi_{0} +\frac{\pi }{3} \right )\] \[i_{12}(t)=\sqrt{2}\cdot \frac{I_{t_{1}}}{\sqrt{3}}\cdot \sin \left ( \omega t+\varphi_{0} +\frac{\pi }{3} \right )\]](/forum/latexrender/pictures/8c11fa142978ca65652e7a99f526a9de.png)
![\[i_{23}(t)=\sqrt{2}\cdot \frac{I_{t_{2}}}{\sqrt{3}}\cdot \sin \left ( \omega t+\varphi_{0} +\frac{\pi }{3}\right)\] \[i_{23}(t)=\sqrt{2}\cdot \frac{I_{t_{2}}}{\sqrt{3}}\cdot \sin \left ( \omega t+\varphi_{0} +\frac{\pi }{3}\right)\]](/forum/latexrender/pictures/1b279e6128da6316d45aa98b98534a27.png)
![\[i_{31}(t)=\sqrt{2}\cdot \frac{I_{t_{3}}}{\sqrt{3}}\cdot \sin \left ( \omega t+\varphi_{0} +\frac{\pi }{3}\right)\] \[i_{31}(t)=\sqrt{2}\cdot \frac{I_{t_{3}}}{\sqrt{3}}\cdot \sin \left ( \omega t+\varphi_{0} +\frac{\pi }{3}\right)\]](/forum/latexrender/pictures/7ff45e9b00b6bb788c5d972e313c1881.png)
oppure c'è una via più semplice e più chiara?? del tipo..
![\[i_{12}(t)=\sqrt{2}\cdot {I_{12}}\cdot \sin \left ( \omega t \right )\] \[i_{12}(t)=\sqrt{2}\cdot {I_{12}}\cdot \sin \left ( \omega t \right )\]](/forum/latexrender/pictures/de133f4fe12579c31427a352c5a4c8a3.png)
![\[i_{23}(t)=\sqrt{2}\cdot {I_{23}}\cdot \sin \left ( \omega t -\frac{2}{3}\pi \right )\] \[i_{23}(t)=\sqrt{2}\cdot {I_{23}}\cdot \sin \left ( \omega t -\frac{2}{3}\pi \right )\]](/forum/latexrender/pictures/c1dda0aab1b3dcfee8c1a918eb331313.png)
![\[i_{31}(t)=\sqrt{2}\cdot {I_{31}}\cdot \sin \left ( \omega t +\frac{2}{3}\pi \right )\] \[i_{31}(t)=\sqrt{2}\cdot {I_{31}}\cdot \sin \left ( \omega t +\frac{2}{3}\pi \right )\]](/forum/latexrender/pictures/943e056010c6a5a8c1e072d7e115ee5c.png)
che confusione....
![\[I_{12}=+35.67 + 6.79j\] \[I_{12}=+35.67 + 6.79j\]](/forum/latexrender/pictures/736f8af9a5603fe45cc6d05840dab317.png)
![\[I_{23}=-11,95 -34,28j\] \[I_{23}=-11,95 -34,28j\]](/forum/latexrender/pictures/1e7ede38eb1826f068431f55d51994b3.png)
![\[I_{31}=-23,71 -27,49j\] \[I_{31}=-23,71 -27,49j\]](/forum/latexrender/pictures/b84ca059bcff577935ee9f28cbeb4953.png)
![\[i_{12}(t)=\sqrt{2}\cdot I_{12}\cdot \sin (\omega t)\] \[i_{12}(t)=\sqrt{2}\cdot I_{12}\cdot \sin (\omega t)\]](/forum/latexrender/pictures/89bfc0585643c7863755438f8eb31f70.png)
![\[i_{12}(t)=\[\sqrt{2}\cdot 36.3 A\cdot \sin (\omega t)\] \[i_{12}(t)=\[\sqrt{2}\cdot 36.3 A\cdot \sin (\omega t)\]](/forum/latexrender/pictures/4e0cabcc9f259d6dfb019d900a0d2599.png)
![\[i_{12}(t)=(50,44+9,60j)\cdot \sin (\omega t)\] \[i_{12}(t)=(50,44+9,60j)\cdot \sin (\omega t)\]](/forum/latexrender/pictures/473c60dd0cc4c2d650937fc3037ac8f1.png)
è positiva...![\[I_{31}=-23,71 +27,49j\] \[I_{31}=-23,71 +27,49j\]](/forum/latexrender/pictures/86aaa0c3f0c46f516fe8ee0766a38e70.png)
