Domanda sul Rumore
[1] Domanda sul Rumore
Messaggioda Foto Utenteciccio » 20 apr 2012, 18:30
Salve,
Volevo sapere cosa ne pensavate su questi due tipi di rumore descritti qui sotto (ahimè in lingua inglese)
Periodic impulsive noise, asynchronous to the main frequency (type 3), with a form of
impulses that usually has a repetition rate between 50 and 200 kHz, and which results in
the spectrum with discrete lines with frequency spacing according to the repetition rate.
This type of noise is mostly caused by switching power supplies. A power supply is a
buffer circuit that is placed between an incompatible source and load in order to make
them compatible. Because of its high repetition rate, this noise occupies frequencies
that are too close to each other, and builds therefore frequency bundles that are usually
approximated by narrow bands.
• Periodic impulsive noise, synchronous to the main frequency (type 4), is impulses with a
repetition rate of 50 or 100 Hz and are synchronous with the main powerline frequency.
Such impulses have a short duration, in the order of microseconds, and have a power
spectral density that decreases with the frequency. This type of noise is generally caused
by power supply operating synchronously with the main frequency, such as the power
converters connected to the mains supply.
DOMANDA:
Il rumore di tipo 4 ossia RUMORE PERIODICO IMPULSIVO ASINCRONO CON LA FREQUENZA DI RETE è dato da impulsi (nel tempo?) a frequenza di 50-200kHz e che in frequenza ci da uno spettro discreto. Questo cosa vuol dire? ... che in frequenza mi trovo alcuni impulsi ai 200kHz ai 400 kHz etc... o altro??
Non riesco bene a capire che cosa intende con questo tipo di rumore. Qualcuno può illuminarmi !
Foto Utenteciccio
20 1 1 6
[2] Re: Domanda sul Rumore
Messaggioda Foto UtenteBeppe82 » 20 apr 2012, 18:47
credo che siano armoniche introdotte in rete da apparecchi con alimentazione che assorbe corrente non sinusoidale (ossia con fattore di potenza != 1)
ad esempio il classico traformatore + ponte + banco di condensatori assorbe correnti non sinusoidali ma "impulsive
raddrizzatore semionda --> 50 Hz
doppia semionda --> 100 Hz
Foto UtenteBeppe82
128 1 1 4
[3] Re: Domanda sul Rumore
Messaggioda Foto Utenteciccio » 20 apr 2012, 18:52
ok grazie ma il mio dubbio resta.
In frequenza dice che il rumore è un insieme discreto di righe distanziate di quale frequenza 200 kHz? In pratica se ho capito bene dice che un segnale a impulsi con freq. di 200 kHz (ad esempio) in frequenza da luogo a un rumore con spettro discreto a righe distanziate di quanto ? di 200kHz?
Foto Utenteciccio
20 1 1 6
[4] Re: Domanda sul Rumore
Messaggioda Foto Utentemir » 20 apr 2012, 18:57
Beppe82 ha scritto:armoniche introdotte in rete da apparecchi con alimentazione che assorbe corrente non sinusoidale (ossia con fattore di potenza != 1)
scusa ma con f.d.p uguale ad 1 non sono carichi o utilizzatori puramente resistivi ?
e poi perché
Beppe82 ha scritto:..assorbe corrente non sinusoidale ...
non dovrebbe generarla l'eventuale dispositivo inquinante ?
[5] Re: Domanda sul Rumore
Messaggioda Foto UtenteBeppe82 » 20 apr 2012, 18:58
scusa mi sa che non stiamo comunicando bene :D (mi riferisco a ciccio)
io ho descritto il rumore tipo 4 come chiedevi nel primo post.
questo tipo di rumore è periodico a 50 o 100 Hz, e contiene uno spettro la cui potenza all'aumentare della frequenza
Foto UtenteBeppe82
128 1 1 4
[6] Re: Domanda sul Rumore
Messaggioda Foto Utenteciccio » 20 apr 2012, 19:00
giusto, grazie stavo intendendo il tipo 3 ossia rumore periodico non sincrono con la freq. di rete.
In tal caso cosa ne dici?
Scusa per l'errore
Foto Utenteciccio
20 1 1 6
[7] Re: Domanda sul Rumore
Messaggioda Foto UtenteBeppe82 » 20 apr 2012, 19:07
posso ipotizzare che siano assorbimenti dati da dispositivi che utilizzano tecniche switching, principalmente appunto nel range 50kHz - 200 kHz, ma oggi ci si spinge anche più in su in frequenza
il fatto che siano idealmente tecniche ON OFF da appunto una ripetizione a frequenze moltiple della principale, da qui spettro discreto, chiaramente sempre decrescente all'aumentare della frequenza
Foto UtenteBeppe82
128 1 1 4
[8] Re: Domanda sul Rumore
Messaggioda Foto UtenteBeppe82 » 20 apr 2012, 19:14
certo
mir ha scritto:
Beppe82 ha scritto:e poi perché
il dispositivo sotto test assorbe corrente non sinusoidale
un'immagine trovata in rete, alim trasformatore + ponte + banco condensatori
Immagine
Foto UtenteBeppe82
128 1 1 4
[9] Re: Domanda sul Rumore
Messaggioda Foto Utentemir » 20 apr 2012, 19:15
la presenza delle armoniche (di corrente) sono dovute a carichi di tipo non lineare come computer, dispositivi UPS, computer etc.
[10] Re: Domanda sul Rumore
Messaggioda Foto Utenteciccio » 20 apr 2012, 19:19
Concordo con mir sul discorso sopra, ma come intendete voi il discorso sopra sul rumore??
Lo spettro di frequenza di un rumore di tipo 3 come viene teoricamente??
Qualcuno sa rispondere?
Foto Utenteciccio
20 1 1 6
Torna a Telecomunicazioni
