Errore LaTeX e PFG esportato da Fidocadj
[1] Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto Utentesimo85 » 5 mar 2015, 1:30
Un saluto a tutti O_/
Sto riscontrando un problema con la esportazione FCD→PGF con fidocadj, quindi mi permetto di taggare il buon Foto UtenteDarwinNE (magari conosce già la soluzione). :-)
Avrei bisogno di esportare degli schemi elettrici a LaTeX. Ovviamente ho scelto di usare Fidocadj, e volevo fare una prova con questo schema:
Una volta effettuata la conversione includo tutto in un template personale \LaTeX che uso sempre per i documenti.
Questo il file che ho provato a compilare:
Codice: Seleziona tutto
\documentclass[12pt, a4paper]{article}
\usepackage[left=2cm,right=2cm,top=2cm,bottom=2cm]{geometry}
\usepackage[spanish]{babel}
\usepackage{graphicx}
\selectlanguage{spanish}
\usepackage[utf8]{inputenc}
\usepackage{textcomp}
\usepackage{amsmath}
\usepackage{amsfonts}
\usepackage{amssymb}
\usepackage{hyperref}
\usepackage{listings}
\usepackage{pgfplots}
\usepackage{tikz}
\usepackage{caption}
\usepackage{subcaption}
\begin{document}
%title
\title{\textbf{\large Template}}
\author{\textbf{\large simo85}}
\maketitle
\begin{pgfpicture}{0cm}{0cm}{111pt}{49pt}
% Created by FidoCadJ ver. 0.24.5 kappa, export filter by Davide Bucci
\pgfsetxvec{\pgfpoint{1pt}{0pt}}
\pgfsetyvec{\pgfpoint{0pt}{1pt}}
\pgfsetroundjoin
\pgfsetroundcap
\pgftranslateto{\pgfxy(0,49)}
\begin{pgfmagnify}{1}{-1}
% Layer color definitions
\definecolor{layer0}{rgb}{0.0,0.0,0.0}
\definecolor{layer1}{rgb}{0.0,0.0,0.0}
\definecolor{layer2}{rgb}{0.0,0.0,0.0}
\definecolor{layer3}{rgb}{0.0,0.0,0.0}
\definecolor{layer4}{rgb}{0.0,0.0,0.0}
\definecolor{layer5}{rgb}{0.0,0.0,0.0}
\definecolor{layer6}{rgb}{0.0,0.0,0.0}
\definecolor{layer7}{rgb}{0.0,0.0,0.0}
\definecolor{layer8}{rgb}{0.0,0.0,0.0}
\definecolor{layer9}{rgb}{0.0,0.0,0.0}
\definecolor{layer10}{rgb}{0.0,0.0,0.0}
\definecolor{layer11}{rgb}{0.0,0.0,0.0}
\definecolor{layer12}{rgb}{0.0,0.0,0.0}
\definecolor{layer13}{rgb}{0.0,0.0,0.0}
\definecolor{layer14}{rgb}{0.0,0.0,0.0}
\definecolor{layer15}{rgb}{0.0,0.0,0.0}
% End of color definitions
\color{layer0}
\pgfsetlinewidth{0.35pt}
\pgfline{\pgfxy(29.0,11.0)}{\pgfxy(30.0,15.0)}
\pgfline{\pgfxy(30.0,15.0)}{\pgfxy(31.0,11.0)}
\pgfline{\pgfxy(31.0,11.0)}{\pgfxy(32.0,15.0)}
\pgfline{\pgfxy(32.0,15.0)}{\pgfxy(33.0,11.0)}
\pgfline{\pgfxy(33.0,11.0)}{\pgfxy(34.0,15.0)}
\pgfline{\pgfxy(24.0,13.0)}{\pgfxy(28.0,13.0)}
\pgfline{\pgfxy(29.0,11.0)}{\pgfxy(28.0,13.0)}
\pgfline{\pgfxy(39.0,13.0)}{\pgfxy(35.0,13.0)}
\pgfline{\pgfxy(34.0,15.0)}{\pgfxy(35.0,13.0)}
\pgfline{\pgfxy(54.0,11.0)}{\pgfxy(55.0,15.0)}
\pgfline{\pgfxy(55.0,15.0)}{\pgfxy(56.0,11.0)}
\pgfline{\pgfxy(56.0,11.0)}{\pgfxy(57.0,15.0)}
\pgfline{\pgfxy(57.0,15.0)}{\pgfxy(58.0,11.0)}
\pgfline{\pgfxy(58.0,11.0)}{\pgfxy(59.0,15.0)}
\pgfline{\pgfxy(49.0,13.0)}{\pgfxy(53.0,13.0)}
\pgfline{\pgfxy(54.0,11.0)}{\pgfxy(53.0,13.0)}
\pgfline{\pgfxy(64.0,13.0)}{\pgfxy(60.0,13.0)}
\pgfline{\pgfxy(59.0,15.0)}{\pgfxy(60.0,13.0)}
\pgfline{\pgfxy(79.0,11.0)}{\pgfxy(80.0,15.0)}
\pgfline{\pgfxy(80.0,15.0)}{\pgfxy(81.0,11.0)}
\pgfline{\pgfxy(81.0,11.0)}{\pgfxy(82.0,15.0)}
\pgfline{\pgfxy(82.0,15.0)}{\pgfxy(83.0,11.0)}
\pgfline{\pgfxy(83.0,11.0)}{\pgfxy(84.0,15.0)}
\pgfline{\pgfxy(74.0,13.0)}{\pgfxy(78.0,13.0)}
\pgfline{\pgfxy(79.0,11.0)}{\pgfxy(78.0,13.0)}
\pgfline{\pgfxy(89.0,13.0)}{\pgfxy(85.0,13.0)}
\pgfline{\pgfxy(84.0,15.0)}{\pgfxy(85.0,13.0)}
\pgfline{\pgfxy(96.0,23.0)}{\pgfxy(92.0,24.0)}
\pgfline{\pgfxy(92.0,24.0)}{\pgfxy(96.0,25.0)}
\pgfline{\pgfxy(96.0,25.0)}{\pgfxy(92.0,26.0)}
\pgfline{\pgfxy(92.0,26.0)}{\pgfxy(96.0,27.0)}
\pgfline{\pgfxy(96.0,27.0)}{\pgfxy(92.0,28.0)}
\pgfline{\pgfxy(94.0,18.0)}{\pgfxy(94.0,22.0)}
\pgfline{\pgfxy(96.0,23.0)}{\pgfxy(94.0,22.0)}
\pgfline{\pgfxy(94.0,33.0)}{\pgfxy(94.0,29.0)}
\pgfline{\pgfxy(92.0,28.0)}{\pgfxy(94.0,29.0)}
\pgfline{\pgfxy(71.0,23.0)}{\pgfxy(67.0,24.0)}
\pgfline{\pgfxy(67.0,24.0)}{\pgfxy(71.0,25.0)}
\pgfline{\pgfxy(71.0,25.0)}{\pgfxy(67.0,26.0)}
\pgfline{\pgfxy(67.0,26.0)}{\pgfxy(71.0,27.0)}
\pgfline{\pgfxy(71.0,27.0)}{\pgfxy(67.0,28.0)}
\pgfline{\pgfxy(69.0,18.0)}{\pgfxy(69.0,22.0)}
\pgfline{\pgfxy(71.0,23.0)}{\pgfxy(69.0,22.0)}
\pgfline{\pgfxy(69.0,33.0)}{\pgfxy(69.0,29.0)}
\pgfline{\pgfxy(67.0,28.0)}{\pgfxy(69.0,29.0)}
\pgfline{\pgfxy(46.0,23.0)}{\pgfxy(42.0,24.0)}
\pgfline{\pgfxy(42.0,24.0)}{\pgfxy(46.0,25.0)}
\pgfline{\pgfxy(46.0,25.0)}{\pgfxy(42.0,26.0)}
\pgfline{\pgfxy(42.0,26.0)}{\pgfxy(46.0,27.0)}
\pgfline{\pgfxy(46.0,27.0)}{\pgfxy(42.0,28.0)}
\pgfline{\pgfxy(44.0,18.0)}{\pgfxy(44.0,22.0)}
\pgfline{\pgfxy(46.0,23.0)}{\pgfxy(44.0,22.0)}
\pgfline{\pgfxy(44.0,33.0)}{\pgfxy(44.0,29.0)}
\pgfline{\pgfxy(42.0,28.0)}{\pgfxy(44.0,29.0)}
\pgfline{\pgfxy(39.0,13.0)}{\pgfxy(49.0,13.0)}
\pgfline{\pgfxy(44.0,18.0)}{\pgfxy(44.0,13.0)}
\pgfline{\pgfxy(64.0,13.0)}{\pgfxy(74.0,13.0)}
\pgfline{\pgfxy(69.0,13.0)}{\pgfxy(69.0,18.0)}
\pgfline{\pgfxy(89.0,13.0)}{\pgfxy(94.0,13.0)}
\pgfline{\pgfxy(94.0,13.0)}{\pgfxy(94.0,18.0)}
\pgfline{\pgfxy(29.0,38.0)}{\pgfxy(94.0,38.0)}
\pgfline{\pgfxy(94.0,38.0)}{\pgfxy(94.0,33.0)}
\pgfline{\pgfxy(69.0,33.0)}{\pgfxy(69.0,38.0)}
\pgfline{\pgfxy(44.0,33.0)}{\pgfxy(44.0,38.0)}
\pgfellipse[stroke]{\pgfxy(19.0,26.0)}{\pgfxy(5.0,0)}{\pgfxy(0,5.0)}
\pgfline{\pgfxy(19.0,21.0)}{\pgfxy(19.0,18.0)}
\pgfline{\pgfxy(19.0,31.0)}{\pgfxy(19.0,33.0)}
\pgfline{\pgfxy(19.0,22.0)}{\pgfxy(19.0,24.0)}
\pgfline{\pgfxy(18.0,23.0)}{\pgfxy(20.0,23.0)}
\pgfline{\pgfxy(18.0,29.0)}{\pgfxy(20.0,29.0)}
\pgfline{\pgfxy(19.0,13.0)}{\pgfxy(19.0,18.0)}
\pgfline{\pgfxy(19.0,13.0)}{\pgfxy(24.0,13.0)}
\pgfline{\pgfxy(19.0,33.0)}{\pgfxy(19.0,38.0)}
\pgfline{\pgfxy(19.0,38.0)}{\pgfxy(29.0,38.0)}
\pgfsetlinewidth{0.33pt}
\pgfcircle[fill]{\pgfxy(69,38)}{0.85pt}\pgfcircle[fill]{\pgfxy(69,13)}{0.85pt}\pgfcircle[fill]{\pgfxy(44,38)}{0.85pt}\pgfcircle[fill]{\pgfxy(44,13)}{0.85pt}\pgfsetlinewidth{0.35pt}
\pgfline{\pgfxy(44.0,38.0)}{\pgfxy(44.0,43.0)}
\pgfmoveto{\pgfxy(41.0,43.0)}
\pgflineto{\pgfxy(47.0,43.0)}
\pgflineto{\pgfxy(46.0,44.0)}
\pgflineto{\pgfxy(44.0,46.0)}
\pgflineto{\pgfxy(42.0,44.0)}
\pgfclosepath
\pgfqstroke
\pgfputat{\pgfxy(3,-21)}{\pgfbox[left,top]{v_a}}
\end{pgfmagnify}
\pgfputat{\pgfxy(28,-3)}{\pgfbox[left,top]{R_1}}
\end{pgfmagnify}
\pgfputat{\pgfxy(32,-22)}{\pgfbox[left,top]{R_2}}
\end{pgfmagnify}
\pgfputat{\pgfxy(52,-3)}{\pgfbox[left,top]{R_3}}
\end{pgfmagnify}
\pgfputat{\pgfxy(56,-22)}{\pgfbox[left,top]{R_4}}
\end{pgfmagnify}
\pgfputat{\pgfxy(77,-3)}{\pgfbox[left,top]{R_5}}
\end{pgfmagnify}
\pgfputat{\pgfxy(81,-22)}{\pgfbox[left,top]{R_6}}
\end{pgfmagnify}
\pgfputat{\pgfxy(101,-22)}{\pgfbox[left,top]{v_o}}
\end{pgfmagnify}
\end{pgfmagnify}
\end{pgfpicture}
\end{document}
Uso Texmaker, che però mi restituisce questo tipo di errore:
! Missing $ inserted.
<inserted text>
l.148 ...at{\pgfxy(52,-3)}{\pgfbox[left,top]{R_3}}
I've inserted a begin-math/end-math symbol since I think
you left one out. Proceed, with fingers crossed.
Ed ecco le linee di errore:
:~$ grep -rn '\pgfputat' test.tex
139:\pgfputat{\pgfxy(3,-21)}{\pgfbox[left,top]{v_a}}
142:\pgfputat{\pgfxy(28,-3)}{\pgfbox[left,top]{R_1}}
145:\pgfputat{\pgfxy(32,-22)}{\pgfbox[left,top]{R_2}}
148:\pgfputat{\pgfxy(52,-3)}{\pgfbox[left,top]{R_3}}
151:\pgfputat{\pgfxy(56,-22)}{\pgfbox[left,top]{R_4}}
154:\pgfputat{\pgfxy(77,-3)}{\pgfbox[left,top]{R_5}}
157:\pgfputat{\pgfxy(81,-22)}{\pgfbox[left,top]{R_6}}
160:\pgfputat{\pgfxy(101,-22)}{\pgfbox[left,top]{v_o}}
Qualcuno saprebbe dirmi se è un errore/bug relativo a texmaker o a fidocadj ?
E magari anche come risolvere. :mrgreen:
Come sempre, ringrazio in anticipo.
Foto Utentesimo85
30,9k 7 12 13
Disattivato su sua richiesta
5
[2] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto UtenteDirtyDeeds » 5 mar 2015, 7:50
Le etichette dei componenti le devi scrivere come $R_1$, $R_2$ ecc.
55,9k 7 11 13
[3] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto UtenteDarwinNE » 5 mar 2015, 8:59
Esatto! Foto UtenteDirtyDeeds ha ragione! :ok:
Foto Utentesimo85, mi dici poi come ti trovi con l'esportazione? Per quanto mi riguarda, è una delle cose che più mi servono di FidoCadJ, mi stupisce che siamo in pochissimi a servirsene.
Foto UtenteDarwinNE
31,0k 7 11 13
[4] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto Utentesimo85 » 5 mar 2015, 9:43
Grazie ad entrambi ! :D
DarwinNE ha scritto:mi dici poi come ti trovi con l'esportazione?
Certamente. Stasera posto i risultati. :ok:
EDIT: già fatta. :-)
Ultima modifica di Foto Utentesimo85 il 5 mar 2015, 10:18, modificato 1 volta in totale.
Foto Utentesimo85
30,9k 7 12 13
[5] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto Utentesimo85 » 5 mar 2015, 10:17
Foto UtenteDarwinNE, ho fatto la prova.
test.pdf
(42.91 KiB) Scaricato 113 volte
Sarebbe bene poter controllare lo scalamento dell'immagine.
Diciamo che secondo me le scritte sono sproporzionate rispetto ai componenti.
Non conosco PGF.
Foto Utentesimo85
30,9k 7 12 13
5
[6] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto UtenteDarwinNE » 5 mar 2015, 10:56
La taglia delle scritte è decisa da LaTeX, quindi se vuoi cambiarla puoi utilizzare \small o \footnotesize, inglobando tutto il file esportato da FidoCadJ.
Invece, lo scalamento dell'immagine è controllabile liberamente durante l'esportazione, modificando il "fattore di scala". Io di solito, quando faccio l'esportazione uso da 1.5 a 2.0 come fattore di scala per fare in modo che il disegno sia di taglia accettabile rispetto alle scritte.
Foto UtenteDarwinNE
31,0k 7 11 13
[7] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto Utentesimo85 » 5 mar 2015, 11:23
DarwinNE ha scritto:lo scalamento dell'immagine è controllabile liberamente durante l'esportazione, modificando il "fattore di scala". Io di solito, quando faccio l'esportazione uso da 1.5 a 2.0 come fattore di scala per fare in modo che il disegno sia di taglia accettabile rispetto alle scritte.
:ok: :ok: :ok:
Ecco il risultato con uno scalamento a 2:
Grazie di nuovo a entrambi.
Foto Utentesimo85
30,9k 7 12 13
[8] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto Utentespud » 5 mar 2015, 13:26
DarwinNE ha scritto:mi stupisce che siamo in pochissimi a servirsene.
Ma sai che io l'ho scoperto leggendo questo thread? Non ci avevo mai fatto caso :D :shock:
Atlant.
Foto Utentespud
3.767 3 10 12
[9] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto UtenteDarwinNE » 5 mar 2015, 14:18
Foto Utentesimo85, bel circuito! Dopo che hai fatto l'esportazione una volta, potrai ritoccare la posizione delle etichette di testo in FidoCadJ, magari disattivando la griglia (e manca l'indicazione di polarità di v_0.
Io quando lavoro su un documento grosso che ha molti circuiti magari esportati con scale differenti mi scrivo uno script che fa tutte le esportazioni in un sol colpo, con le caratteristiche volute. Qualcosa del genere (in questo caso con sh):
#!/bin/sh
FIDOCADJ_PATH="../fidocadj.jar"
FIDOCADJ_LIB="/ ....library path...  /Lib_polys_FIDOCADJ"
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf capt_gene_fem.pgf FidoCadJ/capt_gene_fem.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf effet_seebeck.pgf FidoCadJ/effet_seebeck.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf compensation.pgf FidoCadJ/compensation.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf capt_gene_courant.pgf FidoCadJ/capt_gene_courant.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf photomultiplicateur_principe.pgf FidoCadJ/photomultiplicateur_principe.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf photomultiplicateur_realisation.pgf FidoCadJ/photomultiplicateur_realisation.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf photodiode_carac.pgf FidoCadJ/photodiode_carac.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf photomultiplicateur_conditionnement.pgf FidoCadJ/photomultiplicateur_conditionnement.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf photodiode_conditionnement_r.pgf FidoCadJ/photodiode_conditionnement_r.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf transresistance.pgf FidoCadJ/transresistance.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf montage_t.pgf FidoCadJ/montage_t.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf capt_gene_charge.pgf FidoCadJ/capt_gene_charge.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf conditionn_charge.pgf FidoCadJ/conditionn_charge.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r2 pgf capt_resistance.pgf FidoCadJ/capt_resistance.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r1.5 pgf conditionn_2_4_fils.pgf FidoCadJ/conditionn_2_4_fils.fcd
java -jar $FIDOCADJ_PATH -n -d $FIDOCADJ_LIB -c r1.5 pgf pont_wheatstone.pgf FidoCadJ/pont_wheatstone.fcd
Così poi ho tutti i file con i comandi pgf che utilizzo nel testo. Se mi capita di ritoccare qualcosa in un'immagine, non sono obbligato a ricordarmi il fattore di scala, le librerie utilizzate etc.
Foto UtenteDarwinNE
31,0k 7 11 13
5
[10] Re: Errore LaTeX e PFG esportato da Fidocadj
Messaggioda Foto UtenteDarwinNE » 5 mar 2015, 18:29
spud ha scritto:Ma sai che io l'ho scoperto leggendo questo thread?
A me capita spesso di utilizzare disegni fatti in FidoCadJ in presentazioni tecniche o in documenti, dispense e cose del genere. E' la ragione per cui sviluppo ancora questo programma :ok:
Qualcuno volendo potrebbe scrivere un articolo? :cool:
Foto UtenteDarwinNE
31,0k 7 11 13
Visitano il forum: Google [Bot] e 56 ospiti
