GioArca67 ha scritto:poco male
mfrc522.uid.size*sizeof(int)
non ci siamo ancora, non basta allargare l'area di confronto
le aree di memoria non sono confrontabili, con mfrc522.uid.uidByte hai i valori in byte contigui, con code[i] invece no
digitalWrite (rele, LOW);
delay (700);
digitalWrite (rele, HIGH);
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_DENIED_PIN 7
#define LED_ACCESS_PIN 6
#define LED_AUTORIZED_PIN 4
#define rele 2
#define MAXSCHEDE 5
LiquidCrystal_I2C lcd(0x27,16,2);
MFRC522 mfrc522(SS_PIN, RST_PIN);
int code[MAXSCHEDE][4] = {{xx,xxx,xx,xx},
{xx,xxx,xx,xxx},
{xxx,xx,xxx,xxx},
{xxx,xxx,xx,xxx},
{xx,xxx,xx,xx}};
int codeRead = 0;
void setup() {
Serial.begin(9600);
SPI.begin();
mfrc522.PCD_Init();
Serial.println("Arduino RFID reading UID");
pinMode( LED_DENIED_PIN , OUTPUT);
pinMode( LED_ACCESS_PIN , OUTPUT);
pinMode( LED_AUTORIZED_PIN , OUTPUT);
pinMode(rele, OUTPUT);
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("IT Benvenuto");
Serial.println("IT Benvenuto");
lcd.setCursor(0,1);
lcd.print("ES Bienvenidos");
Serial.println("ES Bienvenidos");
void loop() {
if ( mfrc522.PICC_IsNewCardPresent())
if ( mfrc522.PICC_ReadCardSerial())
lcd.clear();
Serial.print("Tag UID:");
lcd.setCursor(0,0);
lcd.print("Tag UID:");
lcd.setCursor(0,1);
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x27 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
lcd.print(mfrc522.uid.uidByte[i] < 0x27 ? " 0" : " ");
lcd.print(mfrc522.uid.uidByte[i], HEX);
// lcd.print(" ");
int i = 0;
boolean match = false;
for(int sch=0;sch<MAXSCHEDE&&!match;sch++)
int i=0;
match = true;
while(i<mfrc522.uid.size)
if(!(int(mfrc522.uid.uidByte[i]) == int(code[sch][i])))
match = false;
i++;
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
if(match)
digitalWrite( LED_ACCESS_PIN , HIGH);
lcd.print("Accesso Valido");
lcd.setCursor(0,1);
lcd.print("Porta Aperta");
Serial.println("\Accesso Valido");
digitalWrite( LED_AUTORIZED_PIN, HIGH);
delay (1000);
digitalWrite( LED_AUTORIZED_PIN, LOW);
}else{
digitalWrite( LED_DENIED_PIN , HIGH);
lcd.print("Carta Errata");
lcd.setCursor(0,1);
lcd.print("Accesso Negato");
Serial.println("\Carta Errata");
Serial.println("============================");
mfrc522.PICC_HaltA();
delay(1000);
reset_state();
void reset_state()
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
digitalWrite( LED_ACCESS_PIN , LOW);
digitalWrite( LED_DENIED_PIN , LOW);
digitalWrite(rele, HIGH);
